First level
Second level
Third level
Values
Configuration/Status Pages
Print
Administration Menu Map
Configuration Page
Supplies Status Page
Usage Page
Paper Path Page
File Directory Page
Current Settings Page
Color Usage Job Log
Other Pages
Print
Demonstration Page
RGB Samples
CMYK Samples
PCL Font List
PS Font List
- ${title}
- ${title}
- ${title}
- ${title}
HP Color LaserJet Enterprise CP5520 Printer Series - Administration menu
Reports menu
General Settings menu
In the following table, asterisks (*) indicate the factory default setting.
First level
Second level
Third level
Fourth level
Values
Date/Time Settings
Date/Time Format
Date Format
DD/MMM/YYYY
MMM/DD/YYYY*
YYYY/MMM/DD
Time Format
12 hour (AM/PM)*
24 hours
Date/Time
Date
Time
Time Zone
Adjust for Daylight Savings
On
Off*
Energy Settings
Sleep Delay
60*
Select sleep delay period from a list.
Optimum Speed/Energy Usage
Faster First Page*
Save Energy
Save More Energy
Save Most Energy
Print Quality
Adjust Color
Highlights
Cyan Density
Magenta Density
Yellow Density
Black Density
-5 to 5
Default = 0
Midtones
Cyan Density
Magenta Density
Yellow Density
Black Density
-5 to 5
Default = 0
Shadows
Cyan Density
Magenta Density
Yellow Density
Black Density
-5 to 5
Default = 0
Restore Color Values
Image Registration
Adjust Tray <X>
Print Test Page
X1 Shift
Y1 Shift
X2 Shift
Y2 Shift
-5.00 mm to 5.00 mm
Default = 0
Auto Sense Mode
Tray 1 Sensing
Full sensing
Expanded sensing*
Transparency Only
Tray X Sensing
Expanded sensing*
Transparency Only
Adjust Paper Types
Select from a list of paper types that the product supports. The available options are the same for each paper type.
Print Mode
Select from a list of print modes.
Default = Auto Sense Mode
Resistance Mode
Normal*
Up
Down
Humidity Mode
Normal*
High
Fuser Temp Mode
Normal*
Up
Down
Paper Curl Mode
Normal*
Reduced
Optimize
Normal Paper
Standard*
Smooth
Light Media
Normal*
Smooth
Heavy Paper
Standard*
Smooth
Envelope Control
Normal*
Alternate 1
Alternate 2
Environment
Normal*
Low Temp
Line Voltage
Normal*
Low Voltage
Tray 1
Normal*
Alternate
Cleaning Control
Normal*
Alternate
Background
Normal*
Alternate 1
Alternate 2
Alternate 3
Media Temp
Normal*
Alternate
Uniformity Control
Normal*
Alternate 1
Alternate 2
Alternate 3
Pre-Rotation
Normal*
Alternate 1
Alternate 2
Alternate 3
Registration
Normal*
Alternate
Transfer Control
Normal*
Alternate 1
Alternate 2
Alternate 3
Moisture Control
Normal*
Alternate
Restore Optimize
Edge Control
Off
Light
Normal*
Maximum
Jam Recovery
Auto*
Off
On
Manage Stored Jobs
Quick Copy Job Storage Limit
1-300
Default = 32
Quick Copy Job Held Timeout
Off*
1 Hour
4 Hours
1 Day
1 Week
Default Folder Name for Stored Jobs
Select from a list of folder names.
Public*
Sort Stored Jobs By
Job Name*
Date
Restore Factory Settings
Reset
All
Calibration
General
Print
Security
Restrict Color
Enable
Disable
Color if Allowed*
Retrieve From USB Settings menu
First level
Second level
Values
Access Code
Enable*
Disable
Print Settings menu
First level
Second level
Values
Manual Feed
Enabled
Disabled*
Courier Font
Regular*
Dark
Wide A4
Enabled
Disabled*
Print PS Errors
Enabled
Disabled*
Print PDF Errors
Enabled
Disabled*
Personality
Auto*
PCL
POSTSCRIPT
PDF
PCL
Form Length
Range: 5 – 128
Default = 60
Orientation
Portrait*
Landscape
Font Source
Internal*
Soft
USB <X>
Font Number
Range: 0 – 999
Default = 0
Font Pitch
Range: 0.44 – 99.99
Default = 10
Font Point Size
Range: 4.00 – 999.75
Default = 12.00
Symbol Set
Select from a list of symbol sets.
Append CR to LF
No*
Yes
Suppress Blank Pages
No*
Yes
Media Source Mapping
Standard*
Classic
Print Options menu
First level
Second level
Values
Number of Copies
Default = 1
Default Paper Size
Select from a list of sizes that the product supports.
Default Custom Paper Size
Inches
X Dimension
Range: 2.99 – 12.28
Default = 12.28
Y Dimension
Range: 5.00 – 18.50
Default = 18.5
MM
X Dimension
Range: 76 – 312
Default = 312
Y Dimension
Range: 127 – 470
Default = 470
Sides
1-sided*
2-sided
Two-Sided Format
Book-style*
Flip-style
Enable Edge to Edge Overrides
Enabled
Disabled*
Display Settings menu
First level
Second level
Values
Display Brightness
Range: -10 to 10
Default = 0
Language
Select from a list of languages that the product supports.
Show IP Address
Display*
Hide
Sleep Mode
Disabled
Use sleep delay*
Use sleep schedule
Balance power savings/Wait time
Inactivity Timeout
Range: 10 – 300 seconds
Default = 60
Clearable Warnings
On
Job*
Continuable Events
Auto continue (10 seconds)*
Press OK to continue
Manage Supplies menu
First level
Second level
Third level
Fourth level
Values
Print Supplies Status
Supply Settings
Black Cartridge
Very Low Settings
Stop
Prompt to continue*
Continue
Low Threshold Settings
1-100%
Color Cartridges
Very Low Settings
Stop
Prompt to continue*
Continue
Cyan Cartridge
Magenta Cartridge
Yellow Cartridge
1-100%
Fuser
Very Low Settings
Stop
Prompt to continue*
Continue
1-100%
Transfer Kit
Very Low Settings
Stop
Prompt to continue*
Continue
1-100%
Color/Black Mix
Auto*
Mostly Color Pages
Mostly Black Pages
Supply Messages
Low Message
On*
Off
Level Gauge
On*
Off
Reset Supplies
New Fuser Kit
No
Yes
New Transfer Kit
No
Yes
Manage Trays menu
First level
Values
Use Requested Tray
Exclusively*
First
Manually Feed Prompt
Always*
Unless loaded
Size/Type Prompt
Display*
Do not display
Use Another Tray
Enabled*
Disabled
Alternative Letterhead Mode
Disabled*
Enabled
Blank Pages
Auto*
Yes
Override A4/Letter
Yes*
No
Network Settings menu
First level
Values
I/O Timeout
Range: 5 – 300 sec
Default = 15
Embedded Jetdirect
See the table that follows for details. These menus have the same structure. If an additional HP Jetdirect network card is installed in the EIO slot, then both menus are available.
First level
Second level
Third level
Fourth level
Fifth level
Values
Print Sec Report
Yes
No*
TCP/IP
Enable
On*
Off
Host Name
Use the arrow buttons to edit the host name.
NPIXXXXXX*
IPv4 Settings
Config Method
Bootp*
DHCP
Auto IP
Manual
Default IP
Auto IP*
Legacy
DHCP Release
Yes
No*
DHCP Renew
Yes
No*
Primary DNS
Range: 0 – 255
Default = xxx.xxx.xx.xx
Secondary DNS
Range: 0 – 255
Default = 0.0.0.0
IPv6 Settings
Enable
On*
Off
Address
Manual Settings
Enable
On
Off*
Address
Select from a provided list.
DHCPV6 Policy
Router Specified
Router Unavailable*
Always
Primary DNS
Secondary DNS
Proxy Server
Proxy Port
Default = 00080
Idle Timeout
Default = 0270
Security
Secure Web
HTTPS Required*
HTTPS Optional
IPSEC
Keep
Disable*
802.1x
Reset
Keep*
Reset Security
Yes
No*
Diagnostics
Embedded Test
LAN HW Test
Yes
No*
HTTP Test
Yes
No*
SNMP Test
Yes
No*
Data Path Test
Yes
No*
Select All Tests
Yes
No*
Execution Time
Range: 1 – 60 hours
Default = 1
Execute
Yes
No*
Ping Test
Dest Type
IPv4
IPv6
Dest IPv4
Range: 0 – 255
Default = 127.0.0.1
Dest IPv6
Default = : : 1
Packet Size
Default = 64
Timeout
Default = 001
Count
Default = 004
Print Results
Yes
No*
Execute
Yes
No*
Ping Results
Packets Sent
Default = 00000
Packets Received
Default = 00000
Percent Lost
Default = 000
RTT Min
Default = 0000
RTT Max
Default = 0000
RTT Average
Default = 0000
Ping In Progress
Yes
No*
Refresh
Yes
No*
Link Speed
Auto*
10T Half
10T Full
100TX Half
100TX Full
100TX Auto
1000T Full
Additional support options
- ${title}
- ${title}
- ${title}
Country/Region:
Vietnam
- ${title}
hp-hero-support-search
- ${title}
