    Fix HP Printer issue on macOS
HP Color LaserJet Enterprise CP5520 Printer Series - Device Maintenance Menu
Backup/Restore menu
Data backup and restoration is the responsibility of the customer/administrator of the product. Service personnel should not back up or restore customer data under any circumstances.
In the following table, asterisks (*) indicate the factory default setting.
Backup/Restore menu
First level
Second level
Third level
Values
Backup Data
Scheduled Backups
Enable Scheduling
Disabled*
Enabled
Backup Time
Default = current time
Days Between Backups
Default = 1
Backup Now
Export Last Backup
Restore Data
Insert a USB drive that contains the backup file.
Calibration/Cleaning menu
First level
Second level
Values
Auto Cleaning
Off*
On
Cleaning Interval
Select from a list of cleaning intervals.
Auto Cleaning Size
Letter*
A4
Print Cleaning Page
Clean Laser Glass
Quick Calibration
Full Calibration
Delay Calibration at Wake/Power On
Yes*
No
USB Firmware Upgrade menu
To display: At the product control panel, select the Device Maintenance menu, and then select the USB Firmware Upgrade menu.
Insert a USB storage device with a firmware upgrade bundle into the USB port, and follow the on-screen instructions.
Service menu
The Service menu is locked and requires a PIN for access. This menu is intended for use by authorized service personnel.
