HP LaserJet 3390 and 3392 All-in-One Printer Series - Replace Control Panel Overlay and Labels
To view a video demonstrating the procedure for removing the part click here to access the Services Media Library (www.hp.com/go/sml). Select Printers and Multifunction under the Product category, select HP Color LaserJet Printers under the Product family, and then select the printer model under the product series category.
Control panel overlay replacement
The control-panel overlay might already be installed.
  1. Lift the scanner cover.
  2. Align the control-panel overlay with the all-in-one.
  3. Beginning in the center of the label and working outward, press the label until it snaps into place.
Parts return
