HP Officejet Pro 8000 Enterprise Printer Series - Print documents
With certain types of paper, you can print on both sides of a sheet of paper (called “two-sided printing” or “duplex printing”).
Print documents (Windows)
  1. Load paper in the tray.
  2. On the File menu in your software application, click Print.
  3. Make sure the printer you want to use is selected.
  4. To change settings, click the button that opens the Properties dialog box. Depending on your software application, this button might be called Properties, Options, Printer Setup, Printer, or Preferences.
  5. Change the paper orientation on the Finishing tab, and paper source, media type, paper size, and quality settings on the Paper/Quality tab. To print in black and white, click the Color tab, and then change the Print in Grayscale option.
  6. Click OK.
  7. Click Print or OK to begin printing.
Print documents (Mac OS X)
  2. From the File menu in your software application, click Print.
  4. Change the print settings for the option provided in the pop-up menus, as appropriate for your project.
    Click the blue disclosure triangle next to the Printer selection to access these options.
  5. Click Print to begin printing.
