    Apache Log4j Update
HP t5565 Thin Client Specifications
Product description
HP t5565 Thin Client is designed with up-to-date technology and wizard-based utilities for a simple and secure access device that is easy to deploy and manage.
Product features
Feature
VIA VX900 Media System Processor north/south bridge unified chip
Processor
VIA Nano u3500 1 GHz
Memory
Flash memory: 1GB Flash
System memory: 1GB DDR3 SODIMM (128MB reserved for video)
Graphics
VIA ChromotionHD 2.0 Integrated Graphics Processor
Client Aggregation Support for controlling up to 4 devices with one keyboard and mouse, practical for expanding visible desktop real estate across multiple monitors (see administration guide for more details).
Security features
  • Secure USB compartment with 2 USB 2.0 ports
  • Security lock slot (cable lock sold separately)
  • Smartcard support via PCSC Lite Framework & CCID driver
  • User and Administrator logins for greater content control
  • Read-only operating system
Networking
  • 10/100/1000 Ethernet (RJ-45)
  • DHCP or Static IP support
  • Wake on LAN (WOL)
  • PXE (requires bios change)
Input/Output/peripheral support
Keyboard: (USB or PS/2) varies by region
Mouse: (USB or PS/2) varies by region
Printer: Local and/or network printers (RDP, ICA, LPD)
Video: DVI-I & DVI-D digital video output (plus included DVI-I-to-VGA adapter)
Wireless LAN
  • Atheros 802.11a/b/g/n WIFI adapter
  • PCI-Express Half Mini Card
  • Supports 64 and 128-bit WEP, WPA, WPA2, AES, TKIP, 802.1x authentication types EAP-TLS, EAP-TTLS, EAP-PEAP, EAP-FAST, LEAP.
Power
Worldwide auto-sensing 100-240 VAC, 50-60 Hz energy-saving automatic power-down, surge-tolerant, ENERGY STAR 2.0 qualified 65 W power supply supplying 19 VDC.
Physical specifications
Features
Dimensions (H x W x D)
Without stand: 209.55 x 58.42 x 215.90 mm (8.25 x 2.30 x 8.5 in)
With stand: 219.70 x 58.42 x 215.90 mm (8.65 x 2.30 x 8.5 in)
With stand: 1.36 kg (3.00 lb)
Temperature
Operating temperature range: 10° to 40°C (50° to 104°F)
Non-operating temperature range: -30° to 60°C (-22° to 140°F)
Humidity (non-condensing)
Operating: 10% to 90%
Non-operating: 5% to 95%
Software/OS
Feature
HP ThinPro
Server OS Compatibility/Support
  • Citrix XenApp 4.5 and 5.0
  • Citrix XenDesktop 3 and 4
  • Citrix Presentation Server 4.0 and 4.5
  • Windows Server 2008 / 2008 R2 Remote Desktop Services
  • Windows 2000/2003 Terminal Server families
  • Unix/Linux Servers (XDMCP/X.11 for X Windows)    Qualified on Linux Enterprise Server 11
  • Mainframes & Mid-Range Servers (see emulations below)
Warranty information
Terms of warranty apply to the individual model purchased. To see if your HP product is still in warranty, go to the HP Product Warranty Check page.
