    We are upgrading our website
HP t5730/t5740/t5630 Thin Client - Unable to Deploy Image Using Altiris Server
Issue
In Microsoft Windows XPe, you cannot deploy or push image over the network via Altiris because the extracted softpaq does not have a Flash.img file to deploy over the network.
Example: When extracted, the sp47032.exe file contains only the flash.ibr image and not flash.img. Flash.img is the format that is required for use in Altiris.
Solution
In order to fix the issue, install the image (sp47032.exe) into the thin client using a USB flash memory device.
Once the installation is complete, connect the thin client to the network and pull the installed image from the thin client via Altiris server. Save the pulled image in .img format. Deploy the .img file to other thin clients in the network.
Country: Flag Vietnam
