HP Color LaserJet CM2320 Multifunction Series Printer - Replace the Memory
To view a video demonstrating the procedure for removing the part click here to access the Services Media Library (www.hp.com/go/sml). Select Printers and Multifunction under the Product category, select HP Color LaserJet Printers under the Product family, and then select the printer model under the product series category.
Memory replacement
The product comes with 160 MB of RAM. The product also has one DIMM slot that can be used to add a 64 MB or 128 MB DIMM. Some available RAM might be used by the product to complete jobs.
Install a memory DIMM
Handling a DIMM without wearing a grounded, antistatic device might damage the DIMM. Touch any metal part of the product or other grounded metal before touching the DIMM.
  1. Use the power switch to turn off the product, and then unplug all of the cables and cords connected to the product.
  2. Open the DIMM door.
  3. Remove the DIMM from the antistatic bag it came in, grasping the DIMM on the top edge.
  4. With the gold contacts facing upward, insert the DIMM in the DIMM seat and press the DIMM body in until the metal retaining pins click.
  5. Close the DIMM door.
  6. Reconnect all cables and cords, and then use the power switch to turn on the product.
  7. Print a configuration page, and then verify that the Memory section shows the new memory amount.
Parts return
