HP Pro 4500 Microtower PC - Specifications
System specifications
Feature
Chassis dimensions (H x W x D)
0.385 x 0.185 x 0.416 m (15.14 x 7.27 x 16.36 in)
Packaged dimensions (D x L x W)
0.498 x 0.613 x 0.268 m (19.63 x 24.13 x 10.56 in)
System weight
7.58 kg (16.7 lb)
Shipping weight
11.24 kg (24.77 lb)
Temperature range
  • Operating: 5° to 35°C (41° to 95°F)
  • Non-operating: -30° to 65°C (-22° to 149°F)
Relative humidity
  • Operating: 10% to 90% (non-condensing at ambient)
  • Non-operating: 5% to 95% (non-condensing at ambient)
Maximum altitude (unpressurized)
  • Operating: 3048 m (10,000 ft)1
  • Non-operating: 9144 m (30,000 ft)1
Ambient air temperature
  • Operating: 5° to 35°C (41° to 95°F) (Test 40°C (0° to 104°F)); Maximum rate of change is 10°C/Hr (50°F/Hr). The upper limit may be limited by the type and number of options installed.
  • Storage: 90% RH @ 60°C for 12 hours (Non-condensing)
Altitude
  • Operating: 0 to 3048 m (0 to 10,000 ft) - This value may be limited by the type and number of options installed.
  • Non-Operating: 0 to 9,144 m (0 to 30,000 ft) Maximum allowable altitude change rate is 365.76 m/min (1200 ft/min).
Shock
Non-Operating:
  • 35 G's (Half-sine Shock)
  • 30 G's (Trapezoidal Shock)
Vibration
  • Operating: Random vibration at 5 Hz @ 0.00025G2 / Hz, 10 Hz @ 0.01G2 / Hz, 100 Hz @ 0.01G2 / Hz, 300 Hz @ 0.00001G2 / Hz 5 Hz to 300 Hz, (0.25 G's nominal).
  • Non-Operating: ~2.09 G (5-500 Hz), Non-Operational
Acoustic noise
  • IDLE (Fixed disk drive spinning): LWAd = 4.3 Bels, Desktop Average LpAm = 32 dBA
  • FIXED DISK (Random write): LWAd = 4.4 Bels, Desktop Average LpAm = 33 dBA
  • DVD-ROM (Sequential Reads): LWAd = 5.5 Bels, Deskside Average LpAm = 44 dBA
Power supply
MT: 250 W PFC HV immunity (410 V/s) and 300 W PFC HV immunity (410 V/s) with a 115 V / 230 V line switch and 300 W 85% efficiency power supply as option for APJ only
1: Operating temperature is de-rated 1°C per 300 m (1000 ft) to 2286 m (7500 ft) above sea level, no direct sustained sunlight. Maximum rate of change is 7.5°C/Hr for MT and 10°C/Hr for SFF. The upper limit may be limited by the type and number of options installed.
Audio
Feature
Audio
  • Realtek ALC662 High Definition audio codec
  • Internal MT PC speaker
  • HP USB JB Thin Powered Speakers
Graphics
Specification
Graphics
  • Intel graphics media accelerator X4500
  • ATI Radeon HD 4550 (512MB) DH PCIe x16 Graphics card
  • ATI Radeon HD 5450 (512MB) FH PCIe x16 card 3C
  • NVIDIA GeForce 315C (1GB) PCIe x16 card
  • NVIDIA GeForce 405 512MB DDR3 FH PCIe x16 card
  • DMS-59 To Dual DVI Y-Cable adapter
Storage
Feature
Media reader
HP 22-in-1 3.5 JB Media card reader
Optical drives (Serial ATA)
  • HP SATA 16X/40X DVD-ROM
  • HP SATA 16X SuperMulti LightScribe
  • HP SATA Blu-ray writer
Input devices
Feature
Keyboard - One of the following
  • HP PS/2 Standard JB keyboard
  • HP USB Standard JB keyboard
Mouse - One of the following
  • HP PS/2 Optical JB mouse
  • HP USB Laser BLK mouse
  • HP USB Optical BLK mouse
Interfaces
Feature
One (1) PS/2 keyboard port
  • One (1) PS/2 keyboard port
  • One (1) PS/2 mouse port
  • One (1) analog VGA video port
  • One (1) DVI-D video port
  • One (1) serial port (rear)
  • One (1) line in; one (1) line out; one (1) microphone in
  • One (1) RJ45 network port
Communication
Feature
Communication
  • Realtek RTL8111E GbE Ethernet Controller
  • Intel Gigabit CT Desktop NIC
  • LSI PCIe x1 56K International SoftModem
Miscellaneous
Specification
Miscellaneous
  • Hood sensor for MT
  • Port control cover
  • HP Chassis (1 bay) security kit
  • HP Chassis (2 bays) security kit
  • HP Parallel port adapter
  • HP Serial/Parallel PCI card
  • HP Serial Port Full Height adapter
  • HP 1394a FireWire 400 PCI card
