    Fix HP Printer issue on macOS
HP and Compaq Desktop PCs - Motherboard Specifications, N-Alvorix-RS880-uATX (Alvorix)
Figure : The N-Alvorix-RS880-uATX (Alvorix) motherboard
 Photograph of motherboard
Form Factor
  • uATX form factor: 24.4cm (9.6 inches) x 24.4cm (9.6 inches).
  • AMD 785G
Front-side bus speed
  • 1333/1066/800MHz
Upgrade Information
Integrated video
Integrated audio
Integrated network
I/O Ports and internal connectors
Jumper settings
Do not change any jumper setting while the computer is on. Damage to the motherboard can result.
Motherboard layout
Figure : layout
Line drawing of motherboard showing components
