    Apache Log4j Update
HP Designjet T2300 eMFP Product Series - The printer seems slow
Here are some possible explanations.
  • Did you set the print-quality to Best or Max Detail? Best-quality and maximum detail prints take longer.
  • Did you specify the correct paper type when loading the paper? Some paper types require more time for printing; for example, photo and coated papers require more drying time between passes. To find out the printer's current paper type setting, see View information about the paperView information about the paper.
  • If your printer is connected by network, check that all components used in the network (network interface cards, routers, switches, cables) are capable of high-speed operation. Is there a lot of traffic from other devices on the network?
  • If your printer is connected by USB, make sure that the USB host controller is Hi-Speed USB; and check that the USB cables are Hi-Speed USB certified.
  • Did you specify Extended drying time in the front panel? Try changing the drying time to Optimal.
