    Apache Log4j Update
HP Designjet T2300 eMFP Product Series - Product maintenance kits
Four maintenance kits are available for your product, containing components that may need to be replaced after long use. When one of them is needed, a message is displayed on the front panel and by the HP Utility.
When you see the message, you should contact HP Support (see Contact HP SupportContact HP Support) and request the maintenance kit. The kits are installed by service engineers only.
