    We are upgrading our website
HP Scanjet Professional 3000 Scanner - Specifications
This document contains product specifications for your scanner.
Scanner specifications
Name
Scanner type
Duplex sheetfed scanner
Size
Width: 285 mm (11.22 in), Depth: 157 (6.18), Height: 163 mm (6.42 in)
2.5 kgs
Scanning element
Contact image sensor (CIS)
Interface
USB 2.0 high speed (compatible with USB 1.1)
Optical resolution
600 x 600 dpi hardware
Power consumption
For power consumption information, see the regulatory_supplement.pdf file on the HP Scanning Software CD.
Energy information
Hewlett-Packard printing and imaging equipment marked with the ENERGY STAR® logo is qualified to the U.S. Environmental Protection Agency’s ENERGY STAR specifications for imaging equipment. The following mark will appear on ENERGY STAR qualified imaging products:
Additional ENERGY STAR qualified imaging product model information is listed at: http://www.hp.com/go/energystar
System requirements
To view minimum and recommended system requirements in Windows and Macintosh, go to Minimum system requirements (c00014015) (in English).
Document specifications
Name
Minimum paper size
74 x 52 mm (2.9 x 2.1 in)
Maximum paper size
215.9 x 864 (8.5 x 34 in)
Minimum paper weight
50 g/m2 (13.3 lbs)
Maximum paper weight
120 g/m2 (32 lbs)
Environmental specifications
Name
Temperature
Operating the scanner: 10° to 35° C (50° to 95° F)
Storage: -40° to 65° C (-40° to 149° F)
Relative humidity
Operating the scanner: 10% to 80° C noncondensing 10° to 35° C(50° to 95° F)
Storage: up to 90% at 0° to 65° C (32° to 149° F)
In the presence of high electromagnetic fields, it is possible the output from the HP scanner may be slightly distorted.
HP is committed to providing our customers with information about the chemical substances in our products as needed to comply with legal requirements such as REACH (Regulation EC No. 1907/2006 of the European Parliament and the Council). A chemical information report for this product can be found at www.hp.com/go/reach.
