    Looking for Site Help?
HP Pavilion p6672l Desktop PC Product Specifications
Base processor
Core-i3-550 (Clarkdale) 3.2 GHz (73W)
  • The speed measurement for DMI (Direct Media Interface) is not applicable.
  • Socket LGA1156
Intel H57 Express
Motherboard
  • Manufacturer: MSI
  • Motherboard Name: MS-7613
  • HP/Compaq motherboard name: Iona-GL8E
Memory
Component
Attributes
Memory Installed
2 GB
Maximum allowed
16 GB (4 x 4 GB) (64-bit OS)
4 GB* (4 x 1 GB) (32-bit OS)
*Actual available memory may be less
Speed supported
PC3-10600 MB/sec
Type
240 pin, DDR3
  • 500 GB SATA 3G (3.0 Gb/sec)
  • 7200 rpm
SuperMulti DVD Burner with LightScribe Technology drive
  • Interface: SATA
  • Data buffer memory: 2 MB minimum
  • LightScribe: yes
  • Disc diameter: 120 mm
  • Write and read speeds for supported formats and disc types are shown in this table:
Formats/Disc types
Write speeds
Read speeds
Storage capacity
DVD
DVD-ROM SL
NA
up to 16x
up to 4.7 GB
DVD-ROM DL
NA
up to 8X
up to 8.5 GB
DVD+R SL
up to 16x
up to 12X
up to 4.7 GB
DVD+R DL
up to 12x
up to 8x
up to 8.5 GB
DVD+RW SL
up to 8x
up to 8x
up to 4.7 GB
DVD+RW DL
not supported
DVD-R SL
up to 16x
up to 12x
up to 4.7 GB
DVD-R DL
up to 12x
up to 8x
up to 8.5 GB
DVD-RW SL
up to 6x
up to 8x
up to 4.7 GB
DVD-RW DL
not supported
DVD-RAM
up to 12x
up to 12x
4.7 GB
CD
CDROM
NA
up to 40X
up to 700 MB
CDR
up to 40X
up to 40X
up to 700 MB
CDRW
up to 32X
up to 32X
up to 700 MB
CD-DA
NA
up to 32X
up to 700 MB
Video CD
NA
up to 16X
up to 700 MB
Wireless
802.11 b/g/n PCI Express Wireless Half-Length Mini Card
Video Graphics
Integrated on motherboard (see motherboard and chipset)
Sound/Audio
High Definition 8-channel audio
  • ALC 888S chipset
Network (LAN)
Integrated 10/100/1000 Base-T networking interface
Memory card reader
  • Supports the following cards:
    • Compact Flash I
    • Compact Flash II
    • IBM Microdrive
    • Secure Digital (SD)
    • mini-SD
    • MultiMediaCard (MMC)
    • Reduced size MultiMediaCard (RS-MMC)
    • MultiMediaCard Plus (MMC plus)
    • MultiMediaCard Mobile (MMC mobile)
    • Memory Stick
    • Memory Stick Pro
    • Memory Stick Duo
    • Memory Stick Pro Duo
    • SmartMedia
    • xD Picture Card (xD = extreme digital)
External I/O ports
I/O ports on the front panel
Port type
Quantity
15-in-1 (4 slot)
One
USB
Two
Headphone
One
Microphone
One
I/O ports on the back panel
Port type
Quantity
USB
Six
S/PDIF out (optical)
One
VGA
One
DVI
One
1394
One
LAN
One
Audio (side speaker out, rear speaker out, center/subwoofer-out , line-in, line-out, microphone)
One Each
Slot type
Quantity
PCI Express x16
One (One available)
PCI Express x1
Three (Three available)
PCI Express x1 minicard socket
One (None available)
Drive bays
Bay type
Quantity
13.33 cm (5.25 inch) external
Two (One available)
8.89 cm (3.5 inch) internal
Two (One available)
Pocket Media Drive
One (One available)
Keyboard and mouse
  • HP USB keyboard
  • HP USB optical mouse
HP provides basic support for software that comes with the computer. For in-depth feature assistance, refer to the help section in the software or on the software vendor's Web site.
Software titles that shipped with PC
Software Category
Software Title
Operating System
  • FreeDOS
  • Vision Diagnostics (Included on disc(s))
Country: Flag Vietnam
