    Fix Windows 10 Update Issues
SUPPORT COMMUNICATION- SECURITY BULLETIN
Document ID: c02498311
Version: 1
HPSBMI02573 SSRT100227 rev.1 - Palm webOS, webOS Doc Viewer, Execution of Arbitrary Code
Notice:: The information in this security bulletin should be acted upon as soon as possible.
Release date : 26-Oct-2010
Last updated : 26-Oct-2010
Potential Security Impact:
Execution of arbitrary code
VULNERABILITY SUMMARY
A potential security vulnerability has been identified with Palm webOS Doc Viewer. This vulnerability could be exploited to execute arbitrary code.
Reference Number
CVE-2010-4025
SUPPORTED SOFTWARE VERSIONS*: ONLY impacted versions are listed.
Palm webOS 1.4.1
BACKGROUND
CVSS 2.0 Base Metrics
Reference
Base Vector
Base Score
CVE-2010-4025
(AV:L/AC:M/Au:N/C:C/I:C/A:C)
6.8
Information on CVSS is documented in HP Customer Notice: HPSN-2008-002
The Hewlett-Packard Company thanks Chris Clark for reporting this vulnerability to webos-security@palm.com.
RESOLUTION
The vulnerability can be resolved by updating affected devices to webOS version 1.4.5 or subsequent. This update will be provided automatically from the wireless carrier.
Note: Until the update has been applied, avoid opening untrusted Word documents.
PRODUCT SPECIFIC INFORMATION
None
HISTORY
Version:1 (rev.1) - 26 October 2010 Initial Release
Third Party Security Patches: Third party security patches that are to be installed on systems running HP software products should be applied in accordance with the customer's patch management policy
System management and security procedures must be reviewed frequently to maintain system integrity. HP is continually reviewing and enhancing the security features of software products to provide customers with current secure solutions.
"HP is broadly distributing this Security Bulletin in order to bring to the attention of users of the affected HP products the important security information contained in this Bulletin.HP recommends that all users determine the applicability of this information to their individual situations and take appropriate action.HP does not warrant that this information is necessarily accurate or complete for all user situations and, consequently, HP will not be responsible for any damages resulting from user's use or disregard of the information provided in this Bulletin.To the extent permitted by law, HP disclaims all warranties, either express or implied, including the warranties of merchantability and fitness for a particular purpose, title and non-infringement."
