HP Scanjet N6350 Networked Document Flatbed Scanner - How to Activate ADF Duplex and Remove Blank Pages Options
The ADF duplex option allows the user to scan both sides of an original loaded through the ADF (Automatic Document Feeder) and remove blank pages helps to remove the blank pages on the final scan.
Details
Please perform the following steps in order to activate the duplex and remove blank pages options:
  1. Place the documents to be scanned face-up in the ADF tray.
  2. Launch HP Scanning (icon on the desktop).
  3. Please select the Profile and then click Change Settings.
  4. Please select the Document (Glass or Feeder) under Scan Type and click Advanced Document Settings.
  5. Select Automatically remove blank pages and Scan both sides from feeder (Duplex) and then click OK.
The above options can be created and set as default profile for the button.
