Document ID: c02493796
Version: 1
HP EliteBook 8440p Notebook PC and HP EliteBook 8440w Mobile Workstation System BIOS Update F.0E
Release date : 27-Aug-2010
Last updated : 27-Aug-2010
DETAILS OF CHANGE
New features:
  • Added a "DriveLock password on restart" option to allow users to enable or disable a prompt for the DriveLock password when restarting the computer.
  • Added an HP DayStarter feature, which is a usability feature that is targeted to provide customized/personalized information to the user in early boot while the main operating system (Windows) boots in the background. For example, while Windows boots in the background, the BIOS can display the user's calendar for the day.
Field issue fixes:
  • Fixed an issue where the computer does not boot from a bootable CD if an external USB CD/DVD drive is used.
  • The time it takes for the Disk Sanitizer process has been shortened.
REASON FOR CHANGE
To implement changes under "Details of Change."
IMPACT OF CHANGE
None
Components affected:
DATE OF CHANGE
Effective date : 30-Sep-2010
Hardware platforms affected : HP EliteBook 8440p Notebook PC, HP EliteBook 8440w Mobile Workstation
