Setting Up the Printer Hardware for HP LaserJet Pro CP1525n and CP1525nw Color Printer Series
  • Prepare the print cartridges
  • Remove packing tape
  • Load paper
  • Connect the power cord and turn on the power
  • Select the language and location
Setting up the product
Follow these steps in order.
Do not connect a USB cable now. If you plan to use a USB cable to connect the printer to the computer, you will be prompted to connect it at the correct time during the software installation.
Step two: Prepare the print cartridges
  1. Select a sturdy, well-ventilated, dust-free area to position the product.
  2. Open the print cartridge door, and then remove the instruction sheet.
    Figure : Open the print cartridge door and remove the instruction sheet
    Image: Open the print cartridge door and remove the instruction sheet.
  3. Pull out the print cartridge drawer.
    Figure : Pull out the print cartridge drawer
    Image: Pull out the print cartridge drawer.
  4. Remove the sealing tape from the print cartridges. Hold the print cartridge down with one hand, and then pull the tab on the left side of each print cartridge straight up. Discard the sealing tape.
    Figure : Remove the print cartridge sealing tape
    Image: Remove the print cartridge sealing tape.
  5. Close the print cartridge drawer.
    Figure : Close the print cartridge drawer
    Image: Close the print cartridge drawer.
  6. Close the print cartridge door.
    Figure : Close the print cartridge door completely
    Image: Close the print cartridge door completely.
Step three: Remove the packing tape
Open the rear door, and then remove the packing tape. Remove the protective film from the control panel display.
Figure : Remove packing tape and protective film
Image: Remove packing tape and protective film.
  1. Pull tray 2 out of the product.
    Figure : Pull out tray 2
    Image: Pull out tray 2.
  2. Slide the paper guides to their outermost positions.
    Figure : Slide out the paper guides
    Image: Slide out the paper guides.
    To load legal-size paper, extend the tray by pressing and holding the extension tab while pulling the front of the tray outward.
    Figure : Extend tray for legal paper
    Image: Extend tray for legal paper.
  3. Place the stack of paper, print side up, in the tray, and then make sure that the stack is flat at all four corners.
  4. Slide the paper guides inward so that they rest against the stack of paper.
    Figure : Slide paper guides inward
    Illustration of sliding the paper guides inward.
  5. Push down on the paper to make sure that the paper stack sits below the paper limit tabs on the sides of the tray.
    Figure : Push down on the paper
    Image: Push down on the paper.
  6. Slide tray 2 into the product.
    Figure : Insert tray 2 into the product
    Image: Insert tray 2 into the product.
Step five: Connect the power cord and turn on the power
  1. Connect the power cord to the product and to the electrical outlet, and then remove the packing tape from the power switch.
    Figure : Connect the power cord and remove packing tape from the power switch
    Image: Connect the power cord and turn on the power.
  2. Press the Power switch to turn on the product. The product initializes and calibrates itself. Wait until the product is idle and silent before proceeding.
    Figure : Press the power switch
    Image: Press the power switch.
Step six: Select language and location
  1. On the control panel, if prompted, press the Right Arrow button () to select the preferred language, and then press OK.
  2. Press OK again to confirm the selection.
  3. Press the Right Arrow button () to select the location, and then press OK.
  4. Press OK again to confirm the selection. The product might restart itself. Wait until the product is idle and silent before proceeding.
Getting started with ePrint
Now you can stay connected and productive on the go with ePrint. ePrint lets you print directly to your ePrint-enabled HP printer using a smartphone, notebook, or other mobile device. For additional information related to setting up and using ePrint, click the link provided.
Country: Flag Vietnam
