    Fix Windows 10 Update Issues
HP ProBook 6450b Notebook PC - Removing and Replacing the Optical Drive
This document is provided to assist in removing and replacing the optical drive for the HP ProBook 6450b Notebook PC.
Minimum skill level
Tools required
Small, Phillips-head (P1) screwdriver.
Parts required
The replacement part number will vary depending on the optical drive that is being replaced. If a part is listed as "Yes" under "Requires Return" then the defective part needs to be returned to HP. Click here for more information on returning parts to HP.
Part Number
Requires Return
Blu-ray ROM with LightScribe DVD±RW SuperMulti Double-Layer Drive
613358-001(Modified)
Yes
DVD±RW SuperMulti Double-Layer Drive with LightScribe
613360-001(Modified)
Yes
DVD-ROM Drive
613359-001(Modified)
Yes
Summary of instructions
To view a video demonstrating the procedure for removing the optical drive, click on the link below. Or use the product video listing on the HP Services Media Library (Click here to go to HP Services Media Library), then select Optical drive from the menu on the upper left hand side of the screen.
Click here to view the optical drive removal video (right-click on the link to open in a new window/tab).
Optical drive removal
  2. note:
    The video shown depicts a different model of the notebook. The same removal and replacement procedures apply to this notebook.
  3. On the bottom of the notebook, loosen the captive P1 Phillips-head screw that secures the optical drive to the bottom of the base enclosure.
  4. Use a small, flat-bladed tool to push out on the metal tab on the rear of the optical drive to partially eject it from the base enclosure.
  5. Grasp the optical drive bezel and pull the optical drive out of the base enclosure.
Optical drive replacement
  1. Insert the optical drive into the base enclosure until its connector is firmly seated.
  2. Tighten the captive P1 Phillips-head screw that secures the optical drive to the bottom of the base enclosure.
Parts return
