    Fix Windows 10 Update Issues
HP ProBook 4321s Notebook PC - Removing and Replacing Switch Cover
This document is provided to assist in removing and replacing the switch cover for the HP ProBook 4326s Notebook PC.
Minimum skill level
Tools required
Captive, Phillips-head (P1) screwdrivers.
Parts required
The replacement part number will vary depending on the switch cover that is being replaced. If a part is listed as "Yes" under "Requires Return" then the defective part needs to be returned to HP.
Part Number
Requires Return
For with 33.8 cm (13.3 in) displays
599567-001 (Modified)
No
For with 33.8 cm (13.3 in) displays, red
607652-001 (Modified)
No
For with 35.6 cm (14.0 in) displays
599568-001 (Modified)
No
For with 35.6 cm (14.0 in) displays, red
607653-001 (Modified)
No
For customers in countries/regions with RoHS legislation* (e.g. EU, China, etc.) restricting the use of hazardous substances in electrical equipment. The use of the Original Spare part is regulated by RoHS legislation. If your unit contains a part that is labelled with the Modified Spare number, the Modified Spare must be ordered as the replacement part. If your unit contains a part that is labelled with the original Spare number, please order the Original Spare as the replacement part. In this case either the original Spare or the Modified Spare may be shipped which will not affect performance or functionality of the unit.
Summary of instructions
To view a video demonstrating the procedure for removing the switch cover, click on the link below. Or use the product video listing on the HP Services Media Library (Click here to go to HP Service Media Library), then select Switch cover from the menu on the upper left hand side of the screen.
Click here to view the switch cover removal video (right-click on the link to open in a new window/tab).
Switch cover removal
  2. Remove the four 3 mm P1 Phillips broad-head screws in the battery bay that secure the switch cover to the base enclosure.
  3. Turn the notebook right side up and open the display fully.
  4. Slide the switch cover toward the rear of the notebook
  5. Remove the switch cover from the base enclosure.
Switch cover replacement
  1. Place the switch cover onto the base enclosure and align the sides and hinge cut outs with the sides and hinges of the base enclosure.
  2. Align the sides, hinge cut outs, and toes with the sides, hinges, and slots of the base enclosure.
  3. Press down on the switch cover and slide it toward the center of the notebook.
  4. Close the display and turn the notebook upside down.
    Ensure that the four tabs on the rear edge of the switch cover are properly seated in their respective notches in the battery bay.
  5. Replace the four 3 mm P1 Phillips-head screws into the battery bay that secure the switch cover to the base enclosure.
