    Fix Windows 10 Update Issues
HP Mini 5102 - Removing and Replacing Memory Modules
This document is provided to assist in removing and replacing the memory modules for the HP Mini 5102.
Minimum skill level
Parts required
The replacement part number will vary depending on the memory modules that is being replaced. If a part is listed as "Yes" under "Requires Return" then the defective part needs to be returned to HP. Click here for more information on returning parts to HP.
Part Number
Requires Return
2GB, 800 MHz, PC2-6400, SDRAM Small Outline Dual In-Line Memory Module (SODIMM)
598858-001 (Modified)
Yes
1GB, 800 MHz, PC2-6400, SDRAM Small Outline Dual In-Line Memory Module (SODIMM)
598861-001 (Modified)
Yes
Summary of instructions
To view a video demonstrating the procedure for removing the memory modules, click on the link below. Or use the product video listing on the HP Services Media Library (Click here to go to HP Service Media Library), then select Memory modules from the menu on the upper left hand side of the screen.
Click here to view the memory modules removal video (right-click on the link to open in a new window/tab).
Memory modules removal
  2. note:
    The video shown depicts a previous notebook. The same removal and replacement procedures apply to the 5102.
  3. Slide the right battery release latch toward the center of the notebook to release the memory cover.
  4. Lift the memory cover and remove it.
  5. Push both arms outward simultaneously to release the memory board to the spring tension position.
    When handling a memory board, use care to prevent touching the memory chips on the board. Touching the memory chips could damage or destroy the memory.
  6. Grasp the memory board by the edges and pull gently to remove it.
  7. Place the memory board in a static dissipative bag.
Memory modules replacement
  1. Remove the memory board from the static dissipative bag.
  2. Align the notch in the memory board with the key in the board receptacle on the system board.
  3. Grasp the memory board by the edges and push gently to replace it.
  4. Press the memory board down to latch the arms.
  5. Toe the memory cover into the base enclosure and press down to secure it.
Verifying successful repair
Power on the server and verify that the BIOS memory and processor messages are displayed on the monitor during the boot process.
Parts return
