HP ProBook 5320m Notebook PC - Removing and Replacing Battery
This document is provided to assist in removing and replacing the battery for the HP ProBook 5320m notebook PC.
Minimum skill level
Parts required
The replacement part number will vary depending on the battery that is being replaced. If a part is listed as "Yes" under "Requires Return" then the defective part needs to be returned to HP.
Part Number
Requires Return
6-cell (62 Wh) high capacity Lithium-Ion
594796-001 (Modified)
No
4-cell (41 Wh) high capacity Lithium-Ion
580956-001 (Modified)
No
Summary of instructions
To view a video demonstrating the procedure for removing the battery, click on the link below. Or use the product video listing on the HP Services Media Library (Click here to go to HP Service Media Library), then select battery from the menu on the upper left hand side of the screen.
Click here to view the battery removal video (right-click on the link to open in a new window/tab).
Battery removal
  2. Slide the battery release latch identified by a battery icon toward the outside of the notebook to partially eject the battery.
  3. Lift the front edge of the battery and remove it from the battery bay.
Battery replacement
  1. Toe the battery into the battery bay.
  2. Press down on the front edge of the battery until it is properly seated and the release latch clicks.
