Compaq 100eu Small Form Factor Business PC - Specifications
Hardware specifications
Features
Dimensions (H x W x D)
Chassis dimensions: 234 x 260 x 112 mm (9.21 x 10.54 x 4.41 in)
System weight
10.2 kg (22.4 lb)
Memory type
PC2-6400 DDR2 SO- DRAM (800-MHz) non-ECC Up to 4GB maximum system memory supported
Temperature
Operating: 0° to 40°C (32° to 104°F)
Non-Operating: -30° to 65°C (-22° to 149°F)
Humidity
Operating: 10% to 90% (non-condensing at ambient)
Non-Operating: 5% to 95% (non-condensing at ambient)
Power supply
65 W
Communications
Features
Integrated Realtek RTL8103EL 10/100 Fast Ethernet Controller
Controller: 8103EL
Data rates supported: 2.5-GHz data rate with X1 link width
