HP Deskjet 1050 Printers - Description of the Control Panel
This document is for HP Deskjet 1050 and 1055 All-in-One printers.
    Figure : Graphic - The control panel of the HP Deskjet 1050 All-in-One series
  1. 1 Power: Turns the product on or off. When the product is off, a minimal amount of power is still used. To completely remove power, turn off the product, then unplug the power cord.
  2. 2 Cancel: Stops the current operation.
  3. 3 Start Copy Black: Starts a black-and-white copy job. Increase the number of copies (up to 10) by pressing the button multiple times. Acts as a resume button after resolving print problems.
  4. 4 Start Copy Color: Starts a color copy job. Increase the number of copies (up to 10) by pressing the button multiple times. Acts as a resume button after resolving print problems.
  5. 5 Attention light: Indicates that there is a paper jam, the printer is out of paper, or some event that requires your attention.
  6. 6 Cartridge light: Indicates low ink or a print cartridge problem.
