HP ENVY 100 (D410) and ENVY 110 (D411) e-All-in-One Printer Series - Copying a Two-sided Original
This document contains steps for copying a two-sided original.
Copying a two-sided original
Use the following steps to copy a two-sided original.
Step one: Load paper
Follow these steps to load paper in the product.
  1. Grasp the lip on the paper tray, and then pull the tray towards you to extend it.
    Figure : Grasp the lip on the paper tray and pull the tray out
    Image:  Grasp the lip of the paper tray.
  2. Slide the paper width guide to its outermost position.
  3. Insert the stack of paper into the input tray with the short edge forward and the print side down.
  4. Push the stack of paper all the way forward, and then adjust the paper width guide so that it rests against the edge of the paper.
    Figure : Push the paper forward in the input tray
    Illustration:  Push the paper forward in the input tray.
  5. Push the tray forward to close it.
Step two: Copy the two-sided original
Follow these steps to copy the two-sided original.
  1. Lift the scanner lid.
    Figure : Lift the scanner lid
    Graphic: Lift the scanner lid
  2. Place the original print-side down on the right, front corner of the scanner glass. See the engraved guide next to the scanner glass for help placing the document.
    Figure : Place the original on the scanner glass
    Graphic:Place the original on the scanner glass
  3. Close the scanner lid.
  4. From the home screen on the product control panel, touch Copy (). A preview of the document displays on the control panel screen.
  5. From the preview screen on the product control panel, touch Settings. The Copy Settings menu displays.
  6. On the Copy Settings menu, touch 2-sided, and then touch 2-sided again to turn the setting on.
  7. Touch Settings to return to the copy preview screen.
  8. On the copy preview screen, touch the Up arrow () or the Down arrow () to select the number of copies.
  9. Touch Black or Color. The product scans the original.
    After the product scans the document, the product prompts you to place the second page on the scanner glass.
  10. When prompted, place the second page on the right, front corner of the scanner glass with the print-side facing down.
    Figure : Place the second page on the scanner glass
    Graphic: Place the second page on the scanner glass
  11. Close the scanner lid, and then touch OK. The product scans the second page, and then prints the two-sided document.
Country: Flag Vietnam
