    We are upgrading our website
Document ID: c02314444
Version: 1
Advisory: HP Z Series Workstations - Windows XP Professional Edition May Hang During Reboot or Shutdown
Release date : 16-Jul-2010
Last updated : 19-Jul-2010
DESCRIPTION
HP Z Series Workstations - Windows XP Professional Edition may hang during reboot or shutdown
Symptoms:
When initiating a restart or shutdown event on a workstation with more than eight cores running Windows XP Professional, the operating system may hang. This issue does not occur when using the HP supplied Windows XP Professional image or recovery media.
For Z400, this error may occur if a 6-core processor is installed and Hyper-Threading is enabled.
For Z600 and Z800, this error may occur if two 6-core processors are installed, or if two quad-core processors are installed and Hyper-Threading is enabled.
sourceInformation
SCOPE
Information in this document applies to the listed systems configured as follows:
Systems:
  • HP Z400 Workstation
  • HP Z600 Workstation
  • HP Z800 Workstation
Operating Systems:
  • Microsoft Windows XP Professional Edition
RESOLUTION
If this error occurs while installing Windows XP Professional Edition, change the option in F10 Setup to only enable two cores. Use the following procedure to complete this task:
  • Power on the workstation
  • During POST press the F10 key
  • Navigate to the 'Advanced' Menu
  • Navigate to the 'Processors' sub-menu
  • Change the setting for 'Active Cores' to '2'
  • Press F10 to save the settings for the 'Active Cores' options
  • Press F10 to exit F10 setup
After installation completes, change the 'Active Cores' setting back to 'All Cores.' To prevent this error from occurring after setup completes, install Microsoft QFE KB958211. A link to this QFE is available at the HP Business Support Center.
Hardware platforms affected : HP Z400 Workstation, HP Z600 Workstation, HP Z800 Workstation
Operating systems affected : Microsoft Windows XP Professional Edition
Support Communication Cross Reference ID : IA02314444
Country: Flag Vietnam
