HP Compaq 6000 Pro All-in-One Business PC
Features
Processor and Speed (One of the following)
Intel Celeron Dual-Core Processors
Intel Pentium Dual-Core Processors
Intel Core 2 Duo Processors
note: |
Intel Q43 express chipset
Graphics
Integrated Intel Graphics Media Accelerator 4500 HD or optional NVIDIA GeForce GT230 discrete graphics
21.5-inch diagonal widescreen full HD WLED anti-glare display (1080p)
Memory
Up to 8GB of DDR3 SDRAM supported, dual channel memory support
NIC
Integrated gigabit network connection (10/100/1000 NIC)
Optional wireless connectivity:
Keyboard
Wired or wireless keyboard
Pointing device
Wired or wireless mouse
Storage
Optical drive
I/O slots
Full height Mini PCIe x1
Half height Mini PCIe x1
Power supply
Integrated graphics
Discrete graphics
Security
Features
Interfaces
6-in-1 media card reader
Supports Secure Digital (SD, SDHC), MultiMedia Card (MMC),
xD-Picture card, Memory stick, Memory stick Pro
DisplayPort 1.1
One (compatible with DP to VGA, DP to DVI, and DP to HDMI adapters)
audio over DisplayPort supported with discrete graphics only
IEEE 1394 port
One
USB 2.0
Seven (2 left side, 5 rear)
Microphone jack
One
Stereo audio headphone jack
One
Stereo audio line out
One
Power connector
One
RJ-45/Ethernet
One
PS/2
Two
IR emitter (blaster) out
One (with TV tuner option only)
TV coax connector
One (with TV tuner option only);
Two in Japan (with TV tuner option only)
B-CAS card reader
One (Japan only)
Audio/Visual
Integrated HD webcam
Optional TV entertainment experience (configurable)
Infrared remote control for Media Center (with TV Tuner)
Graphics
Discrete NVIDIA GeForce GT230 (internal MXM 3.0 connector)
21.5-inch diagonal widescreen full HD WLED anti-glare display,
tilt and swivel adjustments
Resolution: 1920 x 1080 resolution (16:9)
Contrast ratio: 1000:1 typical
Image brightness: 250 nits typical
Vertical viewing angle: 80° left/80° right
Horizontal viewing angle: 80° up/80° down
Memory
Standard
PC3-10600 DDR3 non-ECC SDRAM (runs at 1333 MHz)
Two 200-pin SODIMM slots supporting dual channel memory
Dual-channel
Maximized dual-channel performance requires SODIMMs of the same size and speed in both memory slots.
Communications
Intel gigabit network connection
802.11 PCIe mini wireless module (optional)
Bluetooth wireless technology (optional)
Manageability
Intel standard manageability
Keyboard
Standard HP USB or PS/2 keyboard
Optional HP wireless keyboard
Pointing device
Standard HP USB or PS/2 optical scroll mouse
Two buttons with scroll wheel acting as third button.
Cable length 175 cm (69 in)
Optional HP wireless optical scroll mouse
Operates at ~ 2.4 GHz and supports a working distance of up to 10 m (32 ft)
Storage
Hard Drive
3.5-inch, 7200 rpm, 3.0 Gb/s, Smart IV SATA Hard Drive:
Solid state drive
2.5-inch, 3.0 Gb/s, Smart IV SATA solid state drive:
Slim Optical Drive
Tray-load SuperMulti DVD LightScribe Burner
Option for no optical drive
Features
Standalone power requirements
Electrical ratings
100-240 V, 50/60 Hz, 2.0 A
Idle operating power
Max operating power: < 180 W
Power supply
Integrated graphics
External 150 W power supply, 87% efficiency, active PFC
Discrete graphics
External 180 W power supply, 87% efficiency, active PFC
HP Power Assistant
PC client based power management solution providing a user interface to manage the operating system power plans and power states while estimating the energy cost impact.
Features
Dimensions (H x W x D)
429 mm x 546 mm x 66 mm (220 mm with stand) [16.9 in x 21.5 in x 2.6 in (8.7 in with stand)]
Packaging dimensions (H x W x D)
566 mm x 670 mm x 249 mm (21.9 in x 26.4 in x 9.8 in)
Shipping weight
Approx. 16.9 kg (37.3 lb)
Features
Preinstalled
Supported
Certified
SMBIOS
System Management BIOS, previously known as DMI BIOS, is used to store system management information.
Preinstalled software
(varies by country)
note: |
Features
Temperature
Operating
5° to 35°C (41° to 95°F)
Non-operating
-30° to 65°C (-22° to 149°F)
Relative humidity
Operating
15% to 80% @ 26°C (78.8°F)
Altitude
(unpressurized)
Operating
0 to 2000 m (0 to 6,562 ft)
Non-operating
0 to 4,572 m (0 to 15,000 ft)
BFR/CFR/PVC-free
Yes, except for external power supply and power cord
Arsenic-free display
Yes
Leakage current meets NFPA99
Yes
TAA compliant
Yes
100 V ac
115 V ac
230 V ac
Normal operation
38.3344 W
38.325 W
38.6587 W
Sleep (Energy Star low power mode)
4.0194 W
4.021 W
4.0931 W
Off
2.8496 W
2.8491 W
2.9215 W
100 V ac
115 V ac
230 V ac
Normal operation
131 BTU/hr
131 BTU/hr
132 BTU/hr
Sleep
14 BTU/hr
14 BTU/hr
14 BTU/hr
Off
10 BTU/hr
10 BTU/hr
10 BTU/hr
note: |
System fan off
Sound power
(LWAd, bels)
Sound pressure
(LpAm, decibels)
Idle
3.8
27
Fixed disk
(random writes)
4.1
29
note: |
Features
Eco-Label certifications & declarations
This product has received or is in the process of being certified to the following approvals and may be labeled with one or more of these marks:
Industry standard certifications
