Compaq Evo n1000v Notebook PC - Removing and Replacing Real-Time Clock (RTC) Battery
This document is provided to assist in removing and replacing the real-time clock (RTC) battery for the Compaq Evo n1000v Notebook PC.
Minimum skill level
Tools required
Small, Phillips-head (P1 and P0) screwdrivers
Parts required
The replacement part number will vary depending on the real-time clock (RTC) battery that is being replaced. If a part is listed as "Yes" under "Requires Return" then the defective part needs to be returned to HP.
Part Number
Requires Return
Battery for real time clock (RTC) - 3 V, 36 mA, lithium
279769-001 (Original)
No
Summary of instructions
To view a video demonstrating the procedure for removing the real-time clock (RTC) battery, click on the link below. Or use the product video listing on the HP Services Media Library (Click here to go to HP Service Media Library), then select Real-Time Clock (RTC) Battery from the menu on the upper left hand side of the screen.
Click here to view the real-time clock (RTC) battery removal video (right-click on the link to open in a new window/tab).
Real-time clock (RTC) battery removal
  2. Remove the 3 mm Phillips-head screw that secures the modem cover.
  3. Slide the modem cover toward the center of the enclosure.
  4. Use your finger to lift the inside edge of the modem cover and remove it.
  5. Use a small, flat-bladed, non-conductive tool to flip the RTC battery out of its socket.
Real-time clock (RTC) battery replacement
  1. With the positive (+) side facing up, insert and press the RTC battery into the socket.
  2. Place the modem cover into the enclosure.
  3. Slide the modem cover toward the outside of the enclosure.
  4. Replace the 3 mm Phillips-head screw.
