Compaq Evo n800v Notebook PC - Removing and Replacing Battery
This document is provided to assist in removing and replacing the battery for the Compaq Evo n800v Notebook PC.
Minimum skill level
Parts required
The replacement part number will vary depending on the battery that is being replaced. If a part is listed as "Yes" under "Requires Return" then the defective part needs to be returned to HP. Click here for more information on returning parts to HP.
Part Number
Requires Return
Battery compartment blank filler (Carbon)
286877-001 (Original)
No
Battery compartment blank filler (Silver)
286876-001 (Original)
No
Battery (Primary) - 8-cell lithium-ion (Li-Ion), 4.0 Ah, 62 Wh
281234-001 (Original)
No
Battery (Multi-Bay) - 8-cell lithium-ion (Li-Ion), 14.8 V dc, 3.6 Ah, 53 Wh - For MultiBay use only
267747-001 (Original)
No
MultiBay battery - 8-cell lithium-ion, 3.6 Ah - For nc800 and nw8000 notebooks (Part of DC889A)
413226-001 (Modified)
Yes
Summary of instructions
To view a video demonstrating the procedure for removing the battery, click on the link below. Or use the product video listing on the HP Services Media Library (Click here to go to HP Service Media Library), then select Battery from the menu on the upper left hand side of the screen.
Click here to view the battery removal video (right-click on the link to open in a new window/tab).
Battery removal
  2. Slide and hold the battery release latch in the unlock position.
  3. Use your finger to grasp the notch behind the bezel and slide the battery out of the battery bay.
  4. Remove the battery bezel by sliding it off the end of the battery.
Battery replacement
  1. Slide the battery bezel onto the end of the new battery.
  2. Slide the battery into the battery bay until the battery release latch clicks.
