HP Color LaserJet 1600 Series Printer - Replace the Cassette
To view a video demonstrating the procedure for removing the part click here to access the Services Media Library (www.hp.com/so/sml). Select Printers and Multifunction under the Product category, Select HP Color LaserJet Printers under the Product family, and then select the printer model under the product series category.
Cassette removal
Tray 2 and optional tray 3 are accessed from the front of the printer and hold up to 250 sheets of paper. Tray 2 also supports other media such as envelopes, postcards, transparencies, HP LaserJet glossy paper, and HP LaserJet Photo paper.
Do not fan paper before loading it into trays. Avoid overloading trays.
Avoid using paper that has been stapled. Staples left in reused paper will cause printer damage that will require repairs that may not be covered under the warranty.
  1. Pull tray 2 or optional tray 3 out of the printer and remove any paper.
  2. Remove the new cassette from the package. Place the used cassette in the package for recycling. See the enclosed recycling guide for recycling instructions.
  3. Remove all orange packing material from the tray.
  4. Move the rear guides to match the size of paper that you are loading. Tray 2 and optional tray 3 accept several standard paper sizes.
  5. If printing paper longer than Letter/A4, extend the rear of the tray until it matches the size you are loading.
  6. Slide the media-width guides slightly wider than the print media.
  7. Load the paper. If this is special paper such as letterhead, load it with the side to be printed on facing up and the top edge toward the front of the tray.
  8. Make sure that the stack of paper is flat in the tray at all four corners, and keep it below the height tabs on the media-length guide in the rear of the tray.
  9. Slide the tray into the printer. The back of the tray will protrude from the back of the printer.
Parts return
