    Looking for Site Help?
HP x22LED 21.5-inch WLED Backlit LCD Monitor - Specifications
Physical specifications
Feature
Dimensions (H x W x D)
  • Unpacked with stand: 37.61 x 52.55 x 16.59 cm (14.8 x 20.7 x 6.5 in)
  • Unpacked without stand (head only): 33.18 x 52.55 x 3.8 cm (13.1 x 20.7 x 1.5 in)
  • Packaged: 11.7 x 58.2 x 42.7 cm (4.6 x 22.9 x 16.8 in)
  • Head only: 2.3 kg (5.1 lb)
  • Unpacked: 2.9 kg (6.4 lb)
  • Packaged: 4.68 kg (10.3 lb)
Tilt range
-4° to +13°, (+/- 2°)
Swivel range
No
Height adjustable
No
Pivot rotation
No
Base
Attachable, ships detached
Video cable length
1.8 m (5.9 ft)
Power cable length
1.8 m (5.9 ft)
Environmental specifications
Feature
Temperature
  • Operating: 0° to 40°C (32° to 104°F)
  • Non-operating: -20° to 60°C (-4° to 140°F)
Humidity
  • Operating: 15% to 90% non-condensing
  • Non-operating: 15% to 90% non-condensing
Altitude
  • Operating: 0 to 3658 m (12,000 ft)
  • Non-operating: 0 to 12,192 m (40,000 ft)
Electrical specifications
Feature
Input power
90 - 230 V ac, 50 or 60 Hz
Typical power consumption
30 W
Maximum power consumption
36 W
Power saving
< 1 W
Technical specifications
Feature
LCD panel
21.5-inch Wide-Aspect Active Matrix Thin Film Transistor (TFT)
Viewable image area
54.61 cm (21.5 in) widescreen; diagonally measured
Screen opening (W x H)
47.82 x 26.97 cm (18.8 x 10.6 in)
Panel type
TN with white LED backlight
Aspect ratio
16:9
Viewing angle (typical)
Up to 170° horizontal/160° vertical (10:1 minimum contrast ratio)
Brightness (typical)
250 nits (cd/m2)
Contrast ratio (typical)
1,000:1
Dynamic contrast ratio (typical)
1 Milion:1
Response time (typical)
5 ms (on/off)
Pixel pitch
0.248 mm
Backlight lamp life (to half brightness)
15,000 hours
Color gamut
68%
Horizontal frequency
24 to 83 KHz
Vertical frequency
50 to 75 Hz
Native resolution
1920 x 1080 @ 60 Hz
Preset VESA graphic modes (non-interlaced)
  • 640 x 480 @ 60 Hz
  • 800 x 600 @ 60 Hz
  • 1024 x 768 @ 60 Hz
  • 1280 x 720 @ 60 Hz
  • 1280 x 960 @ 60 Hz
  • 1280 x 1024 @ 60 Hz
  • 1600 x 900 @ 60 Hz
  • 1600 x 1200 @ 60 Hz (scaled down vertically)
  • 1680 x 1050 @ 60 Hz
  • 1920 x 1080 @ 60 Hz
Text mode
720 x 400 @ 70 Hz
Maximum pixel clock speed
170 MHz
User programmable modes
5
Anti-glare
Yes
Anti-static
No
Default color temperature
6500 K
Plug and play
Yes
Input connectors
VGA and DVI-D (with HDCP)
Input impedance
75 Ohms
Sync input
TTL separate synch
Video cable
One DVI-D to DVI-D
Safety certifications
Featuret
Certification and compliance
  • CE
  • FCC
  • C-Tick
  • VCCI
  • BSMI
  • CB
  • TUV-BAUART
  • TUV-S
  • ISO9241-307
  • CSA
  • CCC
  • CEL
  • CSC
  • Energy Star 5.0
Country: Flag Vietnam
