    Apache Log4j Update
HP Designjet 111 Printer Series - Share a printer (Mac OS)
If your computer is connected to a network, you can make your directly connected printer available to other computers on the same network.
  1. Double-click the System Preferences icon on the Dock menu bar on your desktop.
  2. Under Mac OS X 10.4, enable printer sharing by going to Sharing > Services > Printer Sharing.
    Under later versions of Mac OS X, go to Sharing, select Printer Sharing, and then check the printer(s) that you want to share.
  3. Your printer now automatically appears in the list of shared printers displayed by any other computer running Mac OS and connected to your local network.
Any other people wishing to share your printer must install the printer software on their own computers. They will be able to send print jobs, but will not be able to receive information from the printer.
You may find that sharing your directly connected printer with other users will slow down your computer unacceptably.
The best way to share the printer over a network is to connect the printer not to any computer, but to the network.
