HP Designjet 111 Printer Series - Load paper into the rear path
  1. Place the paper in the rear feed, to the left as seen from the rear, with the side upwards that is to be printed on. Align the paper with the left mark on the rear feed. Make sure that the sheet is square-on to the printer, and not skewed.
  2. Push the paper as far as it will go into the printer.
  3. Select Rear manual feed as the paper source in the printer driver.
