HP Designjet Z5200ps Photo Printer - Color management options
The aim of color management is to reproduce colors as accurately as possible on all devices: so that, when you print an image, you see very similar colors as when you view the same image on your monitor.
There are two basic approaches to color management for your printer:
  • Application-Managed Colors: in this case your application program must convert the colors of your image to the color space of your printer and paper type, using the ICC profile embedded in the image and the ICC profile of your printer and paper type.
  • Printer-Managed Colors: in this case your application program sends your image to the printer without any color conversion, and the printer converts the colors to its own color space. The details of this process depend on the graphics language that you are using.
    • PostScript: the PostScript interpreter module inside the printer performs the color conversion using the profiles stored in the printer (including those generated by the HP Color Center) and any additional profiles sent with the PostScript job. This kind of color management is done when you are using the PostScript driver and you specify printer color management or when you send a PostScript, PDF, TIFF or JPEG file directly to the printer through the Embedded Web Server. In either case you have to select the profiles to use as default (in case the job doesn't specify any) and the rendering intent to apply.
    • Non-PostScript (PCL3): the color management is done using a set of stored ICC profiles. This method is somewhat less versatile than the previous methods, but is a little simpler and faster, and can produce good results with standard HP paper types. This kind of color management is done when you are using a non-PostScript driver and you specify printer color management, or when you send a PCL3 file directly to the printer through the Embedded Web Server.
      There are only two color spaces that the printer can convert to its own color space using the stored profiles: Adobe RGB and sRGB if you are using Windows, Adobe RGB if you are using Mac OS. In addition, you can use ColorSync.
      ColorSync is the Mac OS built-in Color Management System; so, when you select ColorSync, color management is performed by Mac OS, and it is done based on the ICC profiles of the specified paper type. ColorSync is available with the PCL3 driver only.
      ColorSync can be selected under Mac OS X 10.4 from the Color Options panel, then select Use Embedded (ICC/ColorSync) from the Source Profile drop-down list. Under Mac OS X 10.5 and 10.6, ColorSync can be selected from the Color Matching panel.
You are recommended to consult the Knowledge Center at http://www.hp.com/go/Z5200ps/knowledgecenter/ to see how to use the color management options of your particular application.
To choose between Application-Managed Colors and Printer-Managed Colors:
  • In the Windows driver dialog: select the Color tab.
  • In the Mac OS Print dialog: select the Color Options panel.
  • In some applications: you can make this choice in the application.
Color management example with Photoshop
In this example, you have an Adobe RGB image that you want to print from Photoshop. There are three ways of doing it.
  • Select Let Photoshop determine colors in Photoshop. Select Application-Managed Colors in the printer driver. Color management is done in Photoshop. This is the recommended way.
  • Select Let printer determine colors in Photoshop. Select Printer-Managed Colors and the sRGB profile in the printer driver. Photoshop converts the image from Adobe RGB to sRGB and sends it to the printer. Color management is done in the printer. Unfortunately, conversion to sRGB results in a loss of gamut, but Photoshop cannot be prevented from converting to sRGB when Let printer determine colors is selected.
  • Select No color management in Photoshop. Select Printer-Managed Colors and the AdobeRGB profile in the printer driver. Photoshop does not perform any conversion, there is no loss of gamut, and color management is done in the printer. However, this method will not work if you are using synchronized color management in Photoshop (see below).
Synchronized color management with Photoshop
If you are using Adobe Photoshop CS2 for Mac OS, or Adobe Photoshop CS3 for Windows, or later versions, the color management options can be automatically synchronized between Photoshop and the driver.
  • If you select Let Photoshop determine colors or No color management in Photoshop, Application-Managed Colors is automatically selected in the driver.
  • If you select Let printer determine colors in Photoshop, Printer-Managed Colors is automatically selected in the driver. The PostScript driver will use the color profile attached to the job by Photoshop.
To enable this Photoshop synchronization under Windows XP, you must download and install the following free software packages from Microsoft's Web site:
  • Microsoft Core XML Services (MSXML) 6.0
  • Microsoft XML Paper Specification Essentials Pack 1.0
