Specification
Dimensions (H x W x D)
Unpacked w/stand
Unpacked w/o stand (head only)
Packaged
Head only
Packaged
Tilt range
-5° to +15°
Swivel range
No
Height adjustable
No
Pivot rotation
No
Base
Attachable, ships detached
- ${title}
- ${title}
hp-hero-support-search
- ${title}
- ${title}
- ${title}
HP S2331a 23-inch Widescreen LCD Monitor - Specifications
Physical specifications
Panel specifications
Specification
Type
23-inch Wide-Aspect Active Matrix TFT (thin film transistor)
58.42 cm (23 in) widescreen
Screen opening (W x H)
51.12 x 28.84 cm (20.14 x 11.36 in)
Panel type
TN
Resolution
1920 X 1080 @ 60 Hz
Aspect ratio
16:9
Viewing angle (typical)
Up to 170° horizontal/160° vertical
Brightness (typical)1
300 nits (cd/m2)
Contrast ratio (typical)1
1,000:1
Dynamic contrast ratio (typical)1
15,000:1
Response time (typical)1
5 ms (On/Off)
Pixel pitch
0.02652 cm
Backlight lamp life (to half brightness)
50,000 hours
Color gamut
72%
On Screen Display (OSD) controls specifications
Specification
Buttons or switches
Menu, "-"/Volume, "+" /Source, "OK"/Auto, Power button
Languages
English/German/Spanish/French/Italian/Simplified Chinese/Traditional Chinese/Japanese/Nederlands/Portuguese
User controls
Brightness, Contrast, Color, Image Control, OSD Control, Management, Language, Information, Factory Reset, Source Control, Exit
Signal interface/performance specifications
Specification
Horizontal frequency
24 to 94 kHz
Vertical frequency
50 to 76 Hz
Native resolution
1920 X 1080 @ 60 Hz
Preset VESA graphic modes (non-interlaced)
Text mode
720 x 400 @ 70 Hz
Maximum pixel clock speed
200 MHz for VGA, 170 MHz for DVI
User programmable modes
Yes (22)
Anti-glare
Yes
Anti-static
No
Default color temperature
6500 K
Video/other inputs specifications
Specification
Plug and play
Yes
Input connectors
VGA (analog), DVI-D w/HDCP
Input impedance
75 Ohms (VGA); 100-Ohms differential (DVI)
Sync input
TTL separate synch
Video cable
(1) 15-pin D-sub (VGA), (1) DVI-D
Video cable lengths
180 cm (5.9 ft)
Power specifications
Specification
Input power
90 to 265 V ac, 45 to 63 Hz, Internal AC adapter
Typical power consumption
50 W
Maximum
55 W
Power saving
< 1 W sleep mode, < 0.5 W Off mode
Power cable length
190 c m (6.2 ft)
Environmental specifications
Specification
Operating temperature
5° to 35°C (41° to 95°F)
Non-operating temperature
-20° to 60°C (-4° to 140°F)
Operating humidity
20% to 80% non-condensing
Non-operating humidity
10% to 85%, 38.7°C max wet-bulb
Operating altitude
+0 to 3,048 m (10,000 ft)
Non-operating altitude
+0 to 12,192 m (40,000 ft)
- ${title}
- ${title}
- ${title}
- ${title}
Country/Region:
Vietnam
- ${title}
