HP Designjet T770 and T1200 Printer Series - Ink cartridge status messages
These are the possible ink cartridge status messages:
  • OK: the cartridge is working normally, with no known problems.
  • Missing: there is no cartridge present, or it is not correctly connected to the printer.
  • Low: the ink level is low.
  • Very low: the ink level is very low.
  • Empty: the cartridge is empty.
  • Reseat: you are recommended to remove the cartridge and then reinsert it.
  • Replace: you are recommended to replace the cartridge with a new cartridge.
  • Altered: there is something unexpected about the cartridge's status.
  • Expired: it is past the cartridge's expiration date.
