HP 4320t Mobile Thin Client - Specifications
Hardware specifications
Features
Dimensions (HxWxD)
  • 27.49 (at front) x 323.50 x 228.08 mm (1.08 (at front) x 12.74 x 8.98 in)
  • 1.93 kg (4.27 lb) without optical drive
  • 2.07 kg (4.58 lb) with optical drive
Stand-Alone power requirements (AC power)
  • Nominal operating voltage: 18.5 V
  • Max operating power: < 65 W
Temperature
Operating:
  • 0° to 35°C (32° to 95°F) (not writing optical)
  • 5° to 35°C (41° to 95°F) (writing optical)
Non-operating:
  • -20° to 60°C (-4° to 140°F)
Relative humidity
Operating:
  • 10% to 90%, non-condensing
Non-operating:
  • 5% to 95%, 38.7°C (101.6°F) maximum wet bulb temperature
Altitude (unpressurized)
Operating:
  • –15.24 to 3048 m (–50 to 10,000 ft)
Non-operating:
  • –15.24 to 12,192 m (–50 to 40,000 ft)
Communications
Feature
Integrated Realtek RTL8151DH-GR 10/100/1000 NIC
  • 10 Mb/s operation (10BASE-T; IEEE 802.3i; IEEE 802.3 clauses 13-14)
  • 100 Mb/s operation (100BASE-TX; IEEE 802.3u; IEEE 802.3 clauses 21-30)
  • 1000 Mb/s operation (1000BASE-T; IEEE 802.3z and 802.3ab; IEEE 802.3 clauses 34-42)
  • Auto-Negotiation (Automatic Speed Selection)
  • Full Duplex Operation at all Speeds, Half Duplex operation at 10 and 100 Mb/s
  • IEEE 802.1p QoS (Quality of Service) Support
  • IEEE 802.1q VLAN support
  • IEEE 802.3x Flow Control (IEEE 802.3 clauses 31-32; configurable)
V.92 56K Data/Fax Modem
Data Mode Capabilities:
  • V.92 data
  • V.8bis
  • V.80
  • V44, V.42bis, MNP5 (Compression)
  • V.42 (LAPM, MNP2-4) (Error Correction)
Fax Mode Capabilities:
  • TIA/EIA-578-B (Class 1)
  • T.30, T.4 (Group 3)
  • V.17
  • V.29
  • V.27ter
  • V.21 Channel 2
Broadcom 4322AGN 802.11a/b/g/n WiFi Adapter
  • IEEE 802.11a
  • IEEE 802.11b
  • IEEE 802.11g
  • IEEE 802.11n
Broadcom 4312G 802.11b/g WiFi Adapter
  • IEEE 802.11b
  • IEEE 802.11g
Audio/Visual
Feature
  • Implementation: IDT 92HD80 High Definition CODEC
  • Keyboard hotkeys: Volume up, volume down, and mute Play, rewind, and fast-forward
  • Full Duplex: Yes
  • Microphone In: Stereo
  • Headphone/Line Out: Stereo
  • Integrated Microphone: Yes
Audio output quality
  • Frequency Response: 20 Hz - 20 KHz
  • Signal to Noise Ratio: > 85 dB
  • Total Harmonic Distortion: 0.01%
  • Noise Floor: -110 dB
  • Play/Record Sampling Rate(s): 8 KHz - 48 KHz
  • DAC: 16, 20 or 24-bit
  • ADC: 16 or 20-bit
Integrated stereo speakers
  • Power rating: 1.5 W
  • Impedance: 4 Ohms
Country: Flag Vietnam
