HP Color LaserJet CP3525 Printer Series - Firmware Readme
This document contains information for the firmware revision number 20100106 06.050.5 and any previous revisions if applicable.
Product Name(s):
  • HP Color LaserJet CP3525
Model Number(s):
  • CC468A
  • CC469A
  • CC470A
  • CC471A
Enhancements and Fixes provided with Firmware revision 06.050.5
Enhancements
The following new functionality or features are provided by this firmware release: (Datecode: 20100106 06.050.5)
Base Product
HP has implemented a new method of page counting (known as Print Usage Tracker), which can be enabled if desired. The administrator or owner of the product has the option either to enable the new counting method or to do nothing. If the new counting method is enabled the device cannot return to the previous counting method. It is important to understand this. If the feature is not enabled, nothing will change on the device and it will continue to count pages the same as it originally did from the factory.
Background
Current page counting methods were designed to enable efficient service and support. The Print Usage Tracker feature implements new page counting methods which are more aligned with today’s job accounting needs.
Additional information
For more information about the Print Usage Tracker feature, visit, www.hp.com/go/support. Navigate to the SUPPORT AND DRIVERS page web page for your product, or search by name or model of your device (for example, HP Color LaserJet CM3530 MFP or model number CC520A). Once you have located your support page search for “Print Usage Tracker”. Additional information may also be obtained by contacting your regions HP Customer Support Center. This information can be located in the “User” manual that came with your product documentation or on the CD-ROM.
How to enable the feature
If desired, use the following steps to enable the new page counting method (known as Print Usage Tracker) via the product’s Embedded Web Server.
  1. Update your device firmware to this release or greater.
  2. Once this is done the Print Usage Tracker acceptance and activation screen will be available from the product’s Embedded Web Server (EWS) at the following location: EWS, Settings, Security, Device Security Settings, Print Usage Tracker.
  3. Review the acceptance screen so that the changes are understood and you are comfortable with how the changes may or may not affect your HP device or product use model.
  4. If you are comfortable with the acceptance statements and the new counting functionality, choose to enable the feature. As stated previously it is very important to understand that once enabled the device cannot return to the previous counting method.
    1. Select I Accept.
    2. Select Enable the Print Usage Tracker feature on this device.
    3. Press Apply.
Currently this functionality can only be enabled through the product’s Embedded Web Server (EWS). In the future, HP will provide the ability to enable this functionality through HP’s Device management software called HP WebJet Admin. The WebJet Admin support pages can be accessed using the following URL: www.hp.com/go/webjetadmin.
Additional enhancements to base product
  • A new feature has been added which will allow the administrator to configure the device to auto recover from intermittent 49.XXXX errors. With this release, the feature will be enabled ON by default. For Single function devices, you will find the selection under the following menu: CONFIGURE DEVICE, SYSTEM SETUP, Auto Recovery. For “M” Series Multifunction Devices you will find the selection under the following menu: ADMINISTRATION, MANAGEMENT, Auto Recovery.
Embedded Jet Direct
N/A
Fixes or improvements
The following fixes or improvements are provided by this firmware release: (Datecode: 20100106 06.050.5)
Base Product
  • Possible 49 error when using PCL5 macros (more likely with USB mass storage device connected).
  • Very slow printing or printer hangs may occur when a very complex Postscript file with large amounts of lineto commands are present.
  • A 49.4c06 may be displayed on the control panel when printing certain files from Excel that contain non-printable characters.
Embedded Jet Direct
  • Incompatibility with Win Server 2008 and 802.1x
  • CA certificate not accessible via SNMP
  • IPP printer-URI-string miss-formatted
  • DHCPINFORM transmit rate too high
COMPONENT
FIRMWARE VERSION
HP CLJ CP3525
DC Controller:
02.066 (25) (No Change)
Embedded JetDirect:
V.38.80.FF
Improvements provided with previous firmware revisions
All improvements with previous revisions of firmware are included within the most current revision.
Enhancements and Fixes provided with Firmware revision 06.040.4
Enhancements
The following new functionality or features are provided by this firmware release: (Datecode: 20091111 06.040.4)
Base Product
  • Numerical and Alpha characters have been added to the images displayed on the control panel during the Power On process. If the device should stall, during the Power On process the administrator should log the numerical and alpha characters and contact an HP regional support center for additional help. This should only be done if turning the power OFF and back ON for a second time does not resolve the stall.
Embedded Jet Direct
N/A
The following fixes or improvements are provided by this firmware release: (Datecode: 20091111 06.040.4)
Base Product
  • When selecting to print all stored jobs from the front control panel you may see a longer than expected delay between stored jobs. With this new behavior you will no longer see a delay between files as long as the job attributes are the same.
  • You may see a postscript Insufficient Memory error when using added 2-byte fonts.
Embedded Jet Direct
  • N/A
COMPONENT
FIRMWARE VERSION
HP CLJ CP3525
DC Controller:
Embedded JetDirect:
V.38.68.FF (No Change)
Enhancements and Fixes provided with Firmware revision 05.059.3
Enhancements
The following new functionality or features are provided by this firmware release: (Datecode: 20090916 05.059.3)
Base Product
  • The Asset Field found in the products EWS (Embedded Web Server) which is used for assigning Asset numbers to a device has been changed to allow support for more characters.
Embedded Jet Direct:
N/A
The following fixes or improvements are provided by this firmware release: (Datecode: 20090916 05.059.3)
Base Product
  • A 49.4c02 may be seen on the control panel when printing large PostScript Files.
  • Some PostScript files generated from SAP applications may print barcodes incorrectly.
Embedded Jet Direct
N/A
COMPONENT
FIRMWARE VERSION
HP CLJ CP3525
DC Controller:
02.066 (25)
Embedded JetDirect:
V.38.68.FF
Enhancements and Fixes provided with Firmware revision 05.058.4
Enhancements
The following new functionality or features are provided by this firmware release: (Datecode: 20090604 05.058.4)
Base Product
  • An enhancement to the paper tray selection capability in the HP paper handling model has been made.
    The following behaviors will now be seen when a PCL5e print job sent from a non- windows application only includes a tray source command (no paper type command) and the source trays paper type has been set to something other than ANY TYPE.
    1. If the Tray Behavior setting for Use Requested Tray is set to Exclusive then the job will only pull from the tray specified in the print stream and will not wonder to another tray.
    2. If the Tray Behavior setting for Use Requested Tray is set to First then the job will pull initially from the tray specified in the print stream and then move to any tray whose type is set to PLAIN and whose size matches the size in the tray originally specified.
  • Support for 3” x 5” paper has been added through Tray 1 only. The Custom paper size for Tray 1 needs to be set to the proper dimensions through the Supplies Status Menu. The UPD 5.0 driver(s) must be used. Tray 1 paper guides will require special snap in guides which can be purchased from HP. Contact your regions HP support center for additional information.
Embedded Jet Direct
N/A
The following fixes or improvements are provided by this firmware release: (Datecode: 20090604 05.058.4)
Base Product
  • Images on slides may be clipped when printing using the PCL 6 driver with Microsoft 2007 applications.
  • PJL returns incorrect USTATUS code for Tray empty.
  • Issues may be seen using the Alternative Letterhead feature.
  • When selecting to print all private jobs, the quantity is reduced to 1 copy and does not take on the value set by the application or driver.
  • Memory hang may be seen when device is first powered ON.
  • A 49.5001 error may be seen on the control panel when a stored job is retrieved.
  • A 49.5f14 error may be seen on the control panel after hours of continuous printing.
Embedded Jet Direct
N/A
COMPONENT
FIRMWARE VERSION
HP CLJ CP3525
DC Controller:
02.064 (23)
Embedded JetDirect:
V.38.67.FF
Enhancements and Fixes provided with Firmware revision 05.057.1
Enhancements
The following new functionality or features are provided by this firmware release: (Datecode: 20081204 05.057.1)
Base Product
N/A
Embedded Jet Direct
N/A
The following fixes or improvements are provided by this firmware release: (Datecode: 20081204 05.057.1)
Base Product
  • PDF printing errors
  • Printing Menu Map time delay
  • Updated Show Me files
  • Translation updates
  • Continuous calibration changes
  • Resend RFU Via USB Dev Port message may appear on the Front Control panel. This firmware will keep this error from appearing after the device has been updated with this version. It will not address the error if it is seen on the Control panel.
  • Improved PostScript printing performance
Embedded Jet Direct
N/A
