HP Compaq nc4010 Notebook PC - Removing and Replacing the Internal Memory Board
This document is provided to assist in removing and replacing the internal memory board for the HP Compaq nc4010 Notebook PC.
Minimum skill level
Parts required
The replacement part number will vary depending on the internal memory board that is being replaced. If a part is listed as "Yes" under "Requires Return" then the defective part needs to be returned to HP. Click here for more information on returning parts to HP.
Part Number
Requires Return
256MB, 266 MHz, PC2100 DDR-SDRAM SO-DIMM memory module
280874-001 (Original)
Yes
512MB, 266 MHz, PC2100 DDR-SDRAM SO-DIMM memory module
280875-001 (Original)
Yes
Summary of instructions
To view a video demonstrating the procedure for removing the internal memory board, click on the link below. Or use the product video listing on the HP Services Media Library (Click here to go to HP Service Media Library), then select Internal Memory Board from the menu on the upper left hand side of the screen.
Click here to view the internal memory board removal video (right-click on the link to open in a new window/tab).
Internal memory board removal
  2. Push both arms outward simultaneously to release the internal memory board to the spring tension position.
  3. Grasp the internal memory board by the edges and pull gently to remove it.
  4. Place the internal memory board in a static dissipative bag.
Internal memory board replacement
  1. Remove the internal memory board from the static dissipative bag.
  2. Locate the alignment slot and align it to the empty board receptacle.
  3. Grasp the internal memory board by the edges and push gently to replace it.
  4. Press the internal memory board down to latch the arms.
