HP Compaq nc4010 Notebook PC - Removing and Replacing the Memory Expansion Board
This document is provided to assist in removing and replacing the memory expansion board for the HP Compaq nc4010 Notebook PC.
Minimum skill level
Tools required
  • Small, flat-bladed screwdriver or a flat-bladed alignment tool
  • Small, Phillips-head (P0 and P1) screwdriver
Parts required
The replacement part number will vary depending on the memory expansion board that is being replaced. If a part is listed as "Yes" under "Requires Return" then the defective part needs to be returned to HP. Click here for more information on returning parts to HP.
Part Number
Requires Return
256MB, 266 MHz, PC2100 DDR-SDRAM SO-DIMM memory module
280874-001 (Original)
Yes
512MB, 266 MHz, PC2100 DDR-SDRAM SO-DIMM memory module
280875-001 (Original)
Yes
Summary of instructions
To view a video demonstrating the procedure for removing the memory expansion board, click on the link below. Or use the product video listing on the HP Services Media Library (Click here to go to HP Service Media Library), then select Memory Expansion Board from the menu on the upper left hand side of the screen.
Click here to view the memory expansion board removal video (right-click on the link to open in a new window/tab).
Memory expansion board removal
  2. Loosen the captive P0 Phillips-head screw that secures the memory expansion cover to the bottom of the notebook.
  3. Use your finger or a flat-bladed tool to lift the inside edge of the memory expansion cover and remove it.
  4. Push both arms outward simultaneously to release the memory expansion board to the spring tension position.
  5. Grasp the memory expansion board by the edges and pull gently to remove it.
  6. Place the memory expansion board in a static dissipative bag.
Memory expansion board replacement
  1. Remove the memory expansion board from the static dissipative bag.
  2. Locate the alignment slot and align it to the empty board receptacle.
  3. Grasp the memory expansion board by the edges and push gently to replace it.
  4. Press the memory expansion board down to latch the arms.
  5. Toe the memory expansion cover into the enclosure.
  6. Tighten the captive P0 Phillips-head screw.
