Compaq Evo n180 Notebook PC - Removing and Replacing the Hard Disk Drive
This document is provided to assist in removing and replacing the hard disk drive for the Compaq Evo n180 Notebook PC.
Minimum skill level
Tools required
Small Phillips-head (P0 or smaller) screwdriver
Parts required
The replacement part number will vary depending on the hard disk drive that is being replaced. If a part is listed as "Yes" under "Requires Return" then the defective part needs to be returned to HP. Click here for more information on returning parts to HP.
Part Number
Requires Return
10GB IDE hard drive
253918-001 (Original)
Yes
20GB hard disk drive - 4200 RPM, 2.5-inch form factor, 9.5 mm thick - (Toshiba) - HDD case/carrier kit not included
253920-001 (Original)
Yes
30GB hard disk drive - 4200 RPM, 2.5-inch form factor, 9.5 mm thick - (Toshiba) - HDD case/carrier kit not included
253921-001 (Original)
Yes
40GB ATA-5 IDE hard disk drive - 4,200 RPM, 9.5 mm height, 70 mm width
262368-001 (Original)
Yes
48GB ATA-5 IDE hard disk drive - 4,200 RPM, 9.5 mm height, 70 mm width
253922-001 (Original)
Yes
Summary of instructions
To view a video demonstrating the procedure for removing the hard disk drive, click on the link below. Or use the product video listing on the HP Services Media Library, (Click here to go to HP Service Media Library) then select Hard Disk Drive from the menu on the upper left hand side of the screen.
Click here to view the hard disk drive removal video (right-click on the link to open in a new window/tab).
Hard disk drive removal
  2. Remove the two silver 5.5 mm Phillips-head screws in the fixed optical drive bay.
  3. Slide the drive out enough to unseat the connector.
  4. Lift the edge of the drive bracket and remove the drive.
  5. Place the hard disk drive in a static dissipative bag.
Hard disk drive replacement
  1. Remove the hard disk drive from the static dissipative bag.
  2. Insert the drive into the bay and slide it in until the connector is seated.
  3. Replace the two silver 5.5 mm Phillips-head screws.
