    Looking for Site Help?
HP Deskjet 1050, 1050A, 2050, and 2050A All-in-One Printer Series - Alignment Page Does Not Print
Issue
The alignment page does not print as expected. This issue usually occurs immediately after you set up the product or install a new cartridge. The lights on the control panel might also blink when the alignment fails.
Try the following solutions in the order presented to resolve the issue. When one of the solutions resolves the issue, there is no need to continue troubleshooting.
Solution one: Make sure that the All-in-One is ready
  1. Make sure that the product is on. If not, press the Power button () to turn it on.
  2. Check the cartridge access door. If the door is open, close it.
    Figure : Close the cartridge access door
    Graphic: Close the cartridge access door
  • If the alignment page prints successfully, you do not need to continue troubleshooting, but you must complete the alignment. Follow the steps printed on the alignment page to complete the alignment.
  • If the alignment page does not print, continue to the next solution in this document.
Solution two: Make sure that the paper is loaded correctly
If paper was not loaded when the alignment page attempted to print, the alignment fails.
Follow these steps to make sure that the paper is loaded correctly.
  1. Gather 10-30 sheets of 216 x 279 mm (8.5 x 11 inch) plain white paper to load into the product.
  2. Tap the stack of paper on a flat surface to align the edges.
  3. Make sure the paper in the stack is:
    • The same size and type
    • Free from dust, wrinkles, tears, or folds
  4. Slide the paper width guide to its outermost position.
  5. Load the stack of paper into the paper tray, print side down. Slide the stack of paper in until it stops.
  6. Slide the paper width guide so that it rests snugly against the paper.
    Figure : Load paper, and then adjust the paper width guide
    Graphic: Load paper, and then adjust the paper width guide
  7. Press the Power button () to resume the alignment.
Solution three: Check the product for packing materials or other debris, and then realign the product
If there is any packing material or other debris inside the product, the alignment fails and the alignment page does not print. Follow these steps to check the product for packing material or other debris, examine the cartridges, and then realign the product.
Follow these steps to check for any obstructions in the product.
  1. Remove all the paper from the tray.
  2. Open the cartridge access door.
    Graphic: Open the cartridge access door
  3. Remove any packing material or debris from inside the product.
    Figure : Remove packing material from inside the product
    Graphic: Remove packing material from inside the product
  4. Close the cartridge access door.
  5. If the lights on the control panel continue to flash, press the Cancel button () to resume the alignment.
    • If the alignment page prints successfully, you do not need to continue troubleshooting, but you must complete the alignment. Follow the instructions printed on the alignment page to complete the alignment.
Solution four: Remove, inspect, and reseat the cartridges
Follow these steps to remove, inspect, and reseat the cartridges to realign the product.
  1. Press the Power button () to turn on the product, if it is not already turned on. Wait until the product is idle and silent before continuing.
  2. Open the cartridge access door. The carriage moves to the center of the product. Wait until the carriage is idle and silent before continuing.
  3. Press down on the top of the tri-color cartridge to release it, and then pull the cartridge out to remove it from its slot.
    Figure : Remove the tri-color cartridge
    Graphic: Remove the tri-color cartridge
    Do not touch the copper-colored contacts or the ink nozzles. Touching these parts can result in clogs, ink failure, and bad electrical connections.
    Figure : Do not touch the contacts or nozzles
    Graphic: Do not touch the contacts or nozzles
  4. If the protective tape is still attached to the cartridge, hold the cartridge by its sides, and then pull the pink pull tab on the cartridge to remove the tape.
    Figure : Remove the protective tape
    Graphic: Remove the protective tape
  5. Inspect the cartridge for any damage or debris.
  6. Slide the cartridge at a slight upward angle into the empty slot, and then gently push it forward until it snaps into place.
    Figure : Insert the cartridge
    Graphic: Insert the cartridge
    • The tri-color cartridge () goes in the slot on the left
    • The black cartridge () goes in the slot on the right
  7. Repeat these steps to remove, inspect, and reseat the black cartridge.
  8. Close the cartridge access door.
    The product automatically prints an alignment page when you reinsert the cartridges and close the cartridge access door.
Solution five: Turn the product off and on again
Follow these steps to turn the product off and then on again to reset the printing mechanism.
  1. Press the Power button () to turn off the product. If the product does not turn off, continue to the next solution.
  2. Wait 60 seconds.
  3. Press the Power button () to turn on the product.
    The product might go through a warm-up period. The product lights might flash and the carriage might move. Wait until the warm-up period finishes before you proceed.
  • If these steps resolved the issue, you do not need to continue troubleshooting.
  • If the issue persists, continue to the next solution.
Solution six: Finish the software installation and manually align the All-in-One
If you have not installed the product software, complete Step one: Finish the software installation. If you previously installed the product software, continue to Step two: Align the product through the print driver.
Follow these steps to finish the software installation.
  1. Press the Cancel button () on the control panel to stop the alignment.
  2. Use one of the following methods to install the software.
    • Insert the software CD that shipped with the product. Follow the on-screen instructions to install the software.
    • Click here to download and install the latest version of the software. Click the model number for your product, and then follow the on-screen instructions to download and install the software.
      Before clicking the link, bookmark this page in your Web browser. After you click the link and the software downloads and installs, use the bookmark to return to this page and proceed with the next step.
Follow these steps to manually align the product through the print driver.
  1. Open the HP product software:
    • Windows XP: Click Start (), click All Programs, click HP, click the folder for your HP product, and then click the icon for your HP product ().
    • Windows Vista or Windows 7: Click the Windows icon (), click All Programs, click HP, click the folder for your HP product, and then click the icon for your HP product ().
    You can also open the HP product software from your computer desktop: double-click the icon for your HP product ().
    The product software opens.
  2. In the product software, double-click Printer Actions ().
  3. Double-click Maintenance Tasks (). The HP Toolbox opens.
  4. Click Align Ink Cartridges, and then follow the on-screen instructions to print the alignment page.
  5. Lift the scanner lid.
  6. Place the alignment page with the printed-side down on the right-front corner of the scanner glass. See the engraved guide next to the scanner glass for help loading the alignment page.
    Figure : Place the alignment page on the scanner glass
    Graphic: Place the alignment page on the scanner glass
  7. Close the scanner lid.
  8. Press the Start Copy Black button () to begin the scan. The product automatically aligns the cartridges.
  9. Wait until the Power light () stops blinking, which indicates that the cartridge alignment is complete.
  1. Gather the following materials:
    • Dry foam-rubber swabs, lint-free cloth, or any soft material that will not come apart or leave fibers (coffee filters work well)
    • Distilled, filtered, or bottled water (tap water might contain contaminants that can damage the cartridges)
      Do not use platen cleaners or alcohol to clean the cartridge contacts. These can damage the cartridge or the product.
  2. If the product is not already on, press the Power button () to turn it on.
  3. Open the cartridge access door. The carriage moves to the center of the product. Wait until the carriage is idle and silent before continuing.
  4. Press down on the top of the tri-color cartridge to release it, and then pull the cartridge out to remove it from its slot.
  5. Hold the cartridge by its sides.
    Figure : Hold the cartridge by its sides
    Image of holding the cartridge by its sides.
  6. Dip a clean foam-rubber swab or lint-free cloth into distilled water, and then squeeze any excess water from it.
  7. Gently wipe the copper-colored contacts with the swab. Repeat this process with new swabs until no ink residue or debris appears on the swab.
      Figure : Clean the contacts
      Graphic: Cleaning the contacts on the cartridge
    1. Copper-colored contacts
    2. Ink nozzles. CAUTION: Do not clean
  8. Set the cartridge on a clean sheet of paper with the cartridge nozzles facing up.
  9. Clean the contacts in the carriage inside the product.
    Figure : Contacts inside the product
    Graphic: Contacts inside the product
  10. Either let the cartridge and the electrical contact inside the carriage sit for 10 minutes to allow the cleaned area to dry, or use a new swab to dry it.
  11. Slide the cartridge at a slight upward angle into the empty slot, and then gently push it forward until it snaps into place.
  12. Repeat these steps to clean the contacts on the other cartridge.
  13. Close the cartridge access door.
Solution eight: Reset and relocate the product
A power reset drains power from the product and returns the product to the same settings after restarting. To eliminate any potential power deficiencies, move the product to another place and plug the product directly into a wall outlet. Follow these steps to reset and relocate the product.
  1. Make sure that the product is on. If necessary, press the Power button () to turn on the product.
  2. With the product turned on, disconnect the power cord from the back of the product.
  3. Relocate the printer to a different power outlet, preferably an outlet in a different room.
  4. Plug the power cord directly into the wall outlet. Do not use a power strip. Do not reconnect the power cord to the back of the product yet.
  5. Load letter or A4 sized unused, plain white paper in the input tray.
  6. Reconnect the power cord to the back of the product.
  7. Press the Power button () to turn on the product.
  8. Try the alignment again.
Contacting HP for service in all countries/regions except Asia Pacific.
If you completed all the preceding steps and your product still has an issue, service the product.
Check your product warranty to determine if your product is still under warranty, and then go to Contact HP Support to schedule a repair or replacement.
Country: Flag Vietnam
