HP Compaq nc6230 Notebook - Removing and Replacing the TouchPad
This document is provided to assist in removing and replacing the TouchPad for the HP Compaq nc6230 Notebook PC.
Minimum skill level
The End-User should possess product-specific knowledge and technical skill on how to service the system, and have familiarity with the operating system.
Tools required
  • Torx 8 (T8) screwdriver
  • Small, flat-bladed screwdriver or a flat-bladed alignment tool
Parts required
The replacement part number will vary depending on the TouchPad that is being replaced. If a part is listed as "Yes" under "Requires Return" then the defective part needs to be returned to HP.
Part Number
Requires Return
Touchpad - Includes cable
379798-001 (Original)
No
Summary of instructions
To view a video demonstrating the procedure for removing the TouchPad, click on the link below. Or use the product video listing on the HP Services Media Library, (Click here to go to HP Service Media Library) then select TouchPad from the menu on the upper left hand side of the screen.
Click here to view the TouchPad removal video (right-click on the link to open in a new window/tab).
TouchPad removal
  2. Use a flat-bladed tool to lift the rear edge of the TouchPad until it disengages from the top cover.
  3. Turn the TouchPad upside down and place it on the palm rest.
  4. Disconnect the TouchPad cable from the system board.
  5. Place the TouchPad in a static dissipative bag.
TouchPad replacement
  1. Remove the TouchPad from the static dissipative bag.
  2. Reconnect the TouchPad cable to the system board.
  3. Toe the front edge of the TouchPad into the top cover.
  4. Push the rear edge of the TouchPad down until it snaps into place.
