HP LaserJet Pro M1210 Multifunction Printer Series - Restoring the Factory Default Settings
Restore the factory-set defaults (M1210 Series only)
Restoring the factory-set defaults returns all of the settings to the factory defaults, and it also clears the fax header name, phone number, and any stored faxes in the product memory.
Restoring the factory-set defaults returns all of the settings to the factory defaults, and it also clears the fax header name, phone number, and any stored faxes in the product memory. This procedure also clears the fax phone book, and deletes any pages that are stored in the memory. The procedure then automatically restarts the product.
  1. On the product control panel, press the Setup  button.
  2. Use the arrows buttons to select the Service menu, and then press the OK button.
  3. Use the arrows buttons to select the Restore Defaults option, and then press the OK button.
    The product automatically restarts.
