HP TouchSmart 9100 Business PC Specifications
Product description
Adds a new touch of style andAdds interactivity to daily work with the all-in-one, multi-touch enabled HP TouchSmart 9100 Business PC. The multi-touch enabled touch-screen technology allows to do more than just touch; it puts new capabilities, such as scroll, drag, flick, pinch, pan, zoom, and rotate at your fingertips and creates an even better way to interact with your HP TouchSmart.
Product features
Feature
  • NVIDIA MCP7A-J chipset
Processors
  • Intel Core 2 Duo Processor P7570 (2.26 GHz, 3MB L2 cache, 1066 MHz FSB) 1
  • Intel Core 2 Duo Processor T6570 (2.10 GHz, 2MB L2 cache, 800 MHz FSB) 1
1: Intel's numbering is not a measurement of higher performance.
Memory
  • Standard:
    • PC3-10600 DDR3 non-ECC SDRAM (runs at 1333 MHz)
    • Two 200-pin SODIMM slots supporting dual channel memory
      • 2GB (1GB x 2)
      • 4GB (2GB x 2)
      • 8GB (4GB x 2)
  • Dual-channel:
    • Maximized dual-channel performance requires SODIMMs of the same size and speed in both memory slots.
Full availability of 4GB or more of memory requires a 64-bit operating system. With Windows 32-bit operating systems, the amount of usable memory is dependent upon your configuration, so that above 3GB all memory may not be available due to system resource requirements.
Graphics
  • Integrated NVIDIA GeForce G200
  • Discrete NVIDIA GeForce GT230, 1GB
Communications
  • Realtek 8111DL Ethernet Connection:
    Integrated 10/100/1000 NIC 1
  • 802.11 PCIe Mini Wireless Module (optional):
    Support for 802.11 b, g, and n draft 2.0 2
    Up to 300 mbps data rate
    Built-in dual antennas
  • Bluetooth Wireless Technology (optional):
    Bluetooth Specification v2.1 compliant
    Works with a wide range of Bluetooth devices
1: The term "10/100/1000" or "Gigabit" Ethernet indicates compliance with IEEE standard 802.3ab for Gigabit Ethernet, and does not connote actual operating speed of 1 Gb/s. For high-speed transmission, connection to a Gigabit Ethernet server and network infrastructure is required.
2: The specifications for 802.11n draft 2.0 are draft specifications and are not final. If the final specifications differ from the draft specifications, it may affect the ability of the PC to communicate with other 802.11n WLAN devices.
Storage
Hard Drive:
  • 3.5-inch, 7200 rpm, 3.0 Gb/s SATA Hard Drive :
    • 250GB
    • 320GB
    • 500GB
  • 3.5-inch SATA Solid State Drive:
    • 64GB
Optical drive
  • Slot-load Blu-ray Combo Drive:
    • Read: 4x max BD-ROM, 8x max DVD-ROM, 24x max CD-ROM
    • Write: 8x max DVD±R, 4x max DVD±R DL, 4x max DVD±RW,         5x max DVD-RAM, 16x max CD-R, 10x max CD-RW
  • Slot-load SuperMulti DVD LightScribe Burner:
    • Read: 8x max DVD-ROM, 24x max CD-ROM
    • Write: 8x max DVD±R, 6x max DVD±R DL, 8x max DVD+RW,         6x max DVD-RW, 5x max DVD-RAM, 24x max CD-R,         24x max CD-RW
  • Option for no optical drive
Power supply
  • Integrated graphics: external 120-watt power supply, 87% efficiency, active PFC
  • Discrete graphics: external 150-watt power supply, 87% efficiency, active PFC
Interfaces
Feature
6-in-1 Media card reader
  • Supports secure digital (SD, SDHC)
  • MultiMedia card (MMC)
  • xD-Picture card
  • Memory stick
  • Memory stick Pro
DVI-D Video out
  • One
IEEE 1394 port
  • One
USB 2.0
  • Five (2 front, 3 rear)
Line in
  • One
Audio headphone jack
  • One
Audio line out
  • One
Audio digital out (SPDIF)
  • One
Power connector
  • One
RJ-45/Ethernet
  • One
IR Emitter (Blaster) out
  • One (with TV tuner option only)
S-Video in
Stereo audio in
TV Coax connector
Interfaces
Feature
  • xD-Picture card
  • Memory stick
  • Memory stick Pro
DVI-D Video out
  • One
IEEE 1394 port
  • One
USB 2.0
Line in
  • One
  • One
Audio line out
  • One
  • One
Power connector
  • One
RJ-45/Ethernet
  • One
S-Video in
Stereo audio in
TV Coax connector
Display specifications
Feature
  • Touch-enabled 23-inch diagonal widescreen BrightView LCD with glass covering, tilt adjustment between 10º and 40º from vertical
Resolution
  • 1920 x 1080 resolution (16:9)
Contrast ratio
  • 1000:1
Image brightness
  • 300 nits typical
Vertical viewing angle
  • 160°
Horizontal viewing angle
  • 160°
Keyboard and pointing devices
Feature
Standard HP USB keyboard
  • 104 keys plus special keys for Mute, Volume Up, Volume Down.
  • Separate numeric keypad.
  • Cable length 130 cm (51 in)
Optional HP wireless keyboard
  • Operates at ~ 2.4 GHz and supports a working distance of up to 10 m (32 ft).
Standard HP USB optical scroll mouse
  • Two buttons with scroll wheel acting as third button.
  • Cable length 175 cm (69 in)
Optional HP wireless optical scroll mouse
Audio/Visual specifications
Feature
High definition audio support
  • Integrated high-performance 2.0 speakers
  • Integrated dual-microphone array
  • Volume control and mute buttons
  • Stereo headphone jack
  • Stereo line in
  • Stereo line out
  • Audio digital out (SPDIF)
Integrated VGA webcam
  • Up to 30 frames/sec
  • 640 x 480 resolution
  • Designed for low light conditions
Optional TV entertainment experience (configurable)
  • Hybrid ATSC/NTSC, Clear QAM, Over the Air TV Tuner, HW encoded
  • Hybrid PAL/DVB-T, Over the Air TV Tuner, HW encoded
  • Hybrid PAL/DMB-T, Over the Air TV Tuner, HW encoded, Hong Kong/China
  • Dual channel ISDB-T/ISDB-S, Over the Air TV Tuner, HW encoded, Japan
Power specifications
Feature
Electrical ratings
  • 100–240 V, 50/60 Hz, 2.0 A
Average operating power
  • 35 W Idle
Max operating power
  • < 150 W
Operating temperature
  • 5° to 35°C (41° to 95°F)
Non-operating temperature
  • -30° to 65°C (–22° to 149°F)
Operating relative humidity
  • 15% to 80% @ 26ºC
Operating altitude
  • 0 to 2000 m (0 to 6562 ft)
Non-operating altitude
  • 0 to 4572 m (0 to 15,000 ft)
Physical specifications
Feature
Dimensions (H x W x D)
  • 447 x 579 x 72 mm (17.6 x 22.8 x 2.8 in)
  • Approx. 11.5 kg (25.4 lb)
Software overview
Feature
  • Genuine Windows 7 Professional Edition 64 1
  • Genuine Windows 7 Professional Edition 32 1
1: System may require upgraded and/or separately purchased hardware and/or a DVD drive to install the Windows 7 software and take full advantage of Windows 7 functionality.
Preinstalled software (varies by country)
  • HP SkyRoom 1.1
  • HP Power Manager
  • HP TouchSmart Browser
  • HP TouchSmart Calendar
  • HP TouchSmart Canvas
  • HP TouchSmart Clock
  • HP TouchSmart DVD
  • HP TouchSmart Hulu
  • HP TouchSmart Live TV
  • HP TouchSmart Music
  • HP TouchSmart Video
  • HP Touch Smart Photo
  • HP TouchSmart Netflix
  • HP TouchSmart RSS Reader
  • HP TouchSmart Twitter
  • HP TouchSmart Weather
  • HP TouchSmart Webcam
  • HP Total Care Advisor
  • PDF Complete
  • McAfee Total Protection 1
  • Microsoft Office Ready with 60-day Office Professional 2007 Trial Edition
1: 60 day trial period for McAfee Total Protection for Small Business software. Internet access required to receive updates. First update included. Subscription required for updates thereafter.
HP power manager
  • Provides real-time reporting of how system settings impact the energy consumed by the PC and the potential savings over time.
SMBIOS
  • System Management BIOS, previously known as DMI BIOS, is used to store system management information.
Security
  • Kensington lock
Safety certifications
Feature
Industry standard certifications
  • UL:
    Yes
  • CSA:
    Yes
  • FCC compliance:
    Yes
  • ENERGY STAR:
    Yes
  • EPEAT:
    Silver
Eco-Label certifications
This product has received or is in the process of being certified to the following approvals and may be labeled with one or more of these marks:
  • US Energy Star
  • IT ECO declaration
  • EPEAT – Silver
Energy consumption
  • 115 Vac:
    • Normal operation: 51.66 W
    • Sleep (Energy Star low   power mode): 3.392 W
    • Off: 0.557 W
  • 230 Vac:
    • Normal operation: 50.32 W
    • Sleep (Energy Star low   power mode): 3.456 W
    • Off: 0.628 W
  • 100 Vac:
    • Normal operation: 52.11 W
    • Sleep (Energy Star low   power mode): 3.37 W
    • Off: 0.555 W
Heat dissipation
Heat dissipation is calculated based on the measured watts, assuming the service level is attained for one hour.
  • 115 Vac:
    • Normal operation: 177 BTU/hr
    • Sleep: 12 BTU/hr
    • Off: 2 BTU/hr
  • 230 Vac:
    • Normal operation: 172 BTU/hr
    • Sleep: 12 BTU/hr
    • Off: 2 BTU/hr
  • 100 Vac:
    • Normal operation: 178 BTU/hr
    • Sleep: 12 BTU/hr
    • Off: 2 BTU/hr
Declared noise emissions (in accordance with ISO 7779 and ISO 9296)
System fan is usually off except when charging the battery
  • System fan off: Sound power (LWAd, bels)
    • Idle: 2.07
    • Fixed Disk (random writes): 2.41
  • System fan off: Sound pressure (LpAm, decibels)
    • Idle: 23.1
    • Fixed Disk (random writes): 26.0
Batteries
  • Batteries used in the product do not contain:
    • Mercury greater the 5ppm by weight
    • Cadmium greater than 10ppm by weight
  • Battery size:
    CR2032 (coin cell)
  • Battery type:
    Lithium
Warranty information
One-year (1-1-1) limited warranty delivers one year of on-site, next business-day service for parts and labor and includes free telephone support 24 x 7.
