    Apache Log4j Update
HP LaserJet 5200 Printer Series - Message "Standard Output Bin Full" is Displayed on Control Panel
Issue
The printer displays Standard Output Bin Full on the control panel and does not print.
Solution
  1. The output bin may be full. Empty the output bin. Printing resumes automatically.
  2. Take a close look at the flaps hanging out the exit of the printer. They should move up and down freely. If one of them is stuck up, broken or dislodged, then a bin full error is displayed.
  3. Open rear exit tray and power on the printer. If the printer comes to a Ready state, close rear tray and try printing.
  4. Clean the paper path below the toner area and exit assembly at the back of the printer. Ensure there is no pieces of paper stuck in the paper path of the printer.
  5. If the error persists, contact HP Support.
