HP Designjet L25500 Printer Series - Ink system tips
Ink system tips
For best results, always follow these guidelines:
  • Install the ink cartridges, printheads and printhead cleaning cartridge before the warranty-ends date, which is printed on the product label and packaging.
    The ink cartridges normally expire some time after the warranty ends. Refer to the ink cartridge information on the front panel for the expiration date.
  • Follow the instructions on the front panel during installation.
  • Allow the printer and the printhead cleaning cartridge to clean the printheads automatically.
  • Avoid unnecessary removal of the ink cartridges and printheads.
  • The ink cartridges should never be removed while the printer is printing. They should be removed only when the printer is ready for you to replace them. The front panel guides you through the replacement procedure.
  • Make sure that you comply with all applicable laws and regulations when disposing of ink system consumables.
Shake the ink cartridges and printheads vigorously before installing them.
Country: Flag Vietnam
