    Looking for Site Help?
HP Compaq L2151w 21.5-inch Slim Widescreen LCD Monitor - Overview
Product description
The L2151w 21.5-inch, 16:9 widescreen LCD Monitor delivers crisp and vivid HD-ready performance in a thin, energy efficient monitor.
Product features
Feature
Model
VQ412AA
Type
21.5-inch Wide-Aspect Active Matrix TFT (thin film transistor)
Viewable Area (diagonal)
54.6 cm (21.5 in) widescreen; diagonally measured
Screen Opening (W x H)
48.02 x 27.17 cm (18.91 x 10.7 in)
Native Resolution
1920 x 1080 @ 60 Hz
Signal Input
VGA, DVI-D, HDCP support
Viewing Angle
Up to 170° horizontal/160° vertical (10:1 minimum contrast ratio)
Brightness (typical)
250 nits (cd/m2)
Backlight Lamp Life (to half brightness)
50K hours typical
Contrast Ratio (typical)
1000:1
Pixel Pitch
0.248 mm x 0.248 mm
Horizontal Frequency
24 to 94 kHz
Vertical Frequency
48 to 76 Hz
User Programmable Modes
Yes
Plug and Play
Yes
Language Selection
Yes
Anti-Glare
Yes
Anti-Static
Yes
Swivel Range
No
Tilt Range
-5° to + 20° vertical
Height Adjustable
No
Pivot Rotation
No
Base
Attachable, ships detached
Country: Flag Vietnam
