HP TouchSmart Desktop PCs - Using the HP TouchSmart Weather Software
This information applies to some HP computers sold in the United States, such as HP TouchSmart 300 and 600 series computers and some IQ500 and IQ800 products that were upgraded to Windows 7. Not all computers sold in the United States can use the Hulu software application.
UPDATING TOUCHSMART
Did you know HP updates its TouchSmart software to add new features and tools? To get the latest features, update the TouchSmart software from the Internet. Go to the HP software and drivers Web site, and type the model of your computer, such as TouchSmart 600-1055. Select your Windows version, and find the HP TouchSmart Weather Application Update. Read the instructions on the Web page to download and install the update.
To find the model number for your computer, press the Ctrl + Alt + S keys on the keyboard. A window displays your computer information including the model number.
Using TouchSmart Weather
HP TouchSmart has a link to a two-day weather forecast (select models only).
The Weather feature is not available in all countries/regions. Weather is offered only in English.
Complete the following steps to set TouchSmart Weather to display the temperature and forecast for your city.
  1. Open HP TouchSmart, and tap the Weather tile.
    Figure : TouchSmart Weather tile
    Figure : Opening the TouchSmart Weather program
  2. Tap the Settings button.
    Figure : Changing the Weather settings
  3. Tap in the Set Location box, and then use your keyboard or the on-screen keyboard to enter a city, state, ZIP code, or postal code.
    Figure : Setting the location
  4. Tap the Search button. Your city displays in the Select Your City box.
  5. Select Fahrenheit or Celsius.
  6. Tap OK to confirm the settings.
  7. Tap the House icon to return to the HP TouchSmart homepage.
Finding your Weather version
To find the TouchSmart Weather version, tap Settings .
The version displays in the lower-left corner of the Settings screen.
