HP Color LaserJet CM2320nf Multifunction Printer - Print on Both Sides/Manual Duplex Using Driver Support
Printing on both sides of the paper (Manual duplex using driver support) from the HP Color LaserJet CM2320MFP Series Printers.
Details
Perform the following steps to manually print on both sides (manual duplex using driver support) of the paper:
  1. Load enough paper into one of the trays to accommodate the print job. If the tray is loaded special paper such as letterhead, load it in one of the following ways:
    • For tray 1, load the letterhead paper face-up with the bottom edge feeding into the printer first.
    • For all other trays, load the letterhead paper face-up with the top edge at the back of the tray.
  2. Click Start, Printers and Faxes, right click on the HP Color LaserJet CM2320MFP printer driver.
  3. Select Printing Preferences from the drop down menu.
  4. On the Finishing tab, select Print on both sides (manually).
  5. Click Apply and then OK.
  6. Open the document that you wish to print.
  7. Go to File menu and select Print option. Follow the instructions in the pop-up window that appears on the computer screen before replacing the output stack in the tray for printing the second half.
  8. If prompted, press the appropriate control-panel button to continue.
