    Apache Log4j Update
HP Notebook PCs - "Windows was unable to find a certificate to log you on to the network" Error Displays When Connecting to Wireless Network
The following error displays on a computer with the XP operating system, while trying to connect to a wireless network internet.
Windows was unable to find a certificate to log you on to the network.
To specify the required certificate to logon the network, perform the following steps.
  1. Click Start, click Control Panel, and then click Network connections.
  2. Right-click the wireless network that is not connected, and then click Properties.
  3. Select the Wireless Networks tab, select the desired wireless network from the Preferred networks: field, and then click Properties.
  4. Select the Authentication tab, and de-select the Enable IEEE 802.1x authentication for this network option.
  5. Click OK to save the settings, and click OK again to close the network connection window.
Restart the notebook and try connecting to the desired wireless network.
